Author Topic: Spring explosion  (Read 5095 times)
Re: Spring explosion
« Reply #15 on: May 23, 2016, 15:54:14 »
Putting this image in the critique section is like a challenge , it is a superb image
The flowers in IR make the tree look like a cotton plant, quite ethereal
the clouds are a bit to bright, if this was my image I might have tried to darken them a bit
while I understand the urge to use many images when doing a pano, I think a more horizontal crop , a bit  above thee clouds is more pleasant for me
Really great work Olivier
side note: using the tiny V1 can be liberating and limitations of the little body often force me to get more creative
Olivier
  • Olivier Anthony
« Reply #16 on: May 23, 2016, 17:50:53 »
Thank you Armando
The problem is that I am enamored with squares...
I will play with the alternate crop that you propose.
And I agree they look like flowers, but they are just leaves, actually. That is the magic of IR!
Yes, everything gets simple when I am not overwhelmed with too many possibilities provided by the camera. It is an advantage for my kind of photography: slow process, slow moving subjects...
Matthew Currie
« Reply #17 on: May 23, 2016, 20:06:09 »
The man on the bench adds a nice touch.
« Reply #18 on: May 23, 2016, 20:32:05 »
Oh I like :)
