Author Topic: Nik Collection is now free!  (Read 15627 times)
Mongo
Re: Nik Collection is now free!
« Reply #15 on: March 25, 2016, 10:56:38 »
Mongo read about this earlier today. Some of these are reasonably good.  However, downloaded the software BUT did NOT instal it yet for two reasons:
1.   if these are not stand alone software, then, as plug-ins they are not likely to work on CS5 (for Mac except one of the plug-ins) - at least that is Mongo's understanding;
2.    Not at all happy with google taking and sharing information about Mongo. Nothing is FREE it seems. Unless Mongo can turn this feature off, he will NOT be installing this so called "FREE" software.
« Reply #16 on: March 25, 2016, 11:04:52 »
As long as these plugins work with one's photo-editing software of choice now, why worry about the future? They function under Windows up to Win10 so we should be well covered on the OS front (don't know about the Mac OS compatibility though).
I guess you are right, though I imagine the problem might be compatibility problems with future versions of Photoshop and Lightroom rather than the OS. I think the reason people worry is because it is tool they use and like, which now seems to enter an uncertain future.
« Reply #17 on: March 25, 2016, 11:13:46 »
Nik plugins work with CS6 and that's all I care to know about.
« Reply #18 on: March 25, 2016, 11:15:14 »
What is Google taking and sharing in this case? I can see you can opt out of sending anonymous usage statistics, is that what you mean? I'm just curious.
« Reply #19 on: March 25, 2016, 11:15:30 »
Nik plugins work with CS2 to CS6 (tested on Windows). CS5 should be OK, unless the Mac version is something special.
Politely refuse to share user information with Google when you install the plugin package.
Most web sites these days with Google ads on them track and echo back much more information anyway. That is why having ad blocking software and firewalls are so important.
Lars Hansen
  • Zealand, Denmark
« Reply #20 on: March 25, 2016, 12:09:46 »
I don't have any host applications (e.g. Photoshop) and the software installation did not create any shortcuts or a program start group - I created shortcuts myself and run the executeables which are located in your program folder in a "Google\Nik Collection" folder. I use Capture One Pro and don't yet know if it integrates with the Nik software - I don't expect it to be the case.
Whether I will miss other features apart from the integration when running the software this way I have no idea.
Ron Scubadiver
« Reply #21 on: March 25, 2016, 16:12:41 »
Obviously the Nik collection was not making money for Google.  I expect it will get minor maintenance, but no real development.
bjornthun
« Reply #22 on: March 25, 2016, 16:24:57 »
Will it be open-sourced?
« Reply #23 on: March 25, 2016, 16:44:02 »
Thanks for the heads up! ;)
« Reply #24 on: March 25, 2016, 17:22:05 »
A nice touch is that these plugins install both 32- and 64-bit executables so will fit straight into any recent computing system.
You can run them as stand-alone programs, no problem. That solves issues with a lack of a suitable hosting application, at the expense of a slightly more convoluted work flow.
Fanie
« Reply #25 on: March 25, 2016, 19:46:05 »
I still use CS2, but that cannot work with D800 files.
Will the Nik standalone run NEF files, or only Jpg's?
Fanie du Plessis
Pretoria,  South Africa
« Reply #26 on: March 25, 2016, 19:49:01 »
Nikon provides free converters (ViewNX and Capture NXD)  to deal with D800 NEFs. The Nik Collection handles 16-bit TIFs or (8-bit) jpgs, but one should not expect too much if an 8-bit jpg is the starting point. Keep to the TIFs.
Fanie
« Reply #27 on: March 25, 2016, 19:53:35 »
Thanks Bjorn, got spoiled with Capture NX that edits directly with the RAW file, but will try it for sure.
Fanie du Plessis
bjornthun
« Reply #28 on: March 25, 2016, 20:15:39 »
Adobe's DNG converter will convert nefs from e.g. Nikon D800 to Adobe DNG format. You may be able to ingest these DNG files into PS CS2.
The Adobe DNG converter is a free download AFAIK.
« Reply #29 on: March 25, 2016, 20:28:37 »
I fail to see the value of going through intermediary DNGs to do 'raw' processing in CS2 instead of dealing directly with the NEFs in suitable RAW converters. Finish the processing of the NEFs there using the power of RAW files, then if required, do any final polishing using Nik standalones or CS2 on output 16-bit TIFs.
