Author Topic: Dandelions Are Free - Installment #1  (Read 11643 times)
Re: Dandelions Are Free - Installment #1
« Reply #30 on: June 21, 2015, 17:53:58 »
Independently, you and Asle have touched the approach I used.
Is a double exposure always enough?
« Reply #31 on: June 21, 2015, 18:08:06 »
d10 exposure delay mode?
« Reply #32 on: June 21, 2015, 18:11:01 »
Nope, that's not what I meant. The Sachtler tripod used here is sturdy enough :D
« Reply #33 on: June 21, 2015, 18:51:09 »
I think I got it now by how the OOF part is rendered; One shot focused on the Dandelions and one off focus or even zoomed out a bit.
Could even be you also changed the angle a bit upwards to keep the 'roots' more or less level in the image...
« Reply #34 on: June 21, 2015, 19:13:55 »
No camera or lens focal movement ....
« Reply #35 on: June 21, 2015, 19:19:32 »
Then I don't see it.
« Reply #36 on: June 21, 2015, 19:20:42 »
Oh Erik you are so close ...
Incidentally, Øivind Tøien skyped me earlier today and we discussed this very photo in depth. When I revealed the technique he was amazed at its simplicity.
« Reply #37 on: June 21, 2015, 19:51:12 »
Vaseline or spit on front element is an ancient way to do this as well.
But was not used here...
« Reply #38 on: June 21, 2015, 20:37:57 »
OK, I spill the beans and reveal it all. But promise not to laugh ...
I worked these dandelions for some hours, in UV as well as in visible light. Light was variable, occasional rain showers caused even more trouble, and wind almost reached gale force after a while, thus without the Sachtler CF ENG HD tripod the mission on that exposed shore would have to be aborted.  For the capture I had my D2X added to the 200-400 mm f/4 ED Nikkor and the zoom set to around 300 mm according to my field notes. What I tried to achieve was a core of recognisable sharpness softened by wind-induced movements. To this end, the camera ran in multiple exposure mode with Auto Gain = Off and the maximum frame number provided (9 if memory serves).
This project was more difficult to achieve than I had imagined and most shots came out with too clearly defined double contours. I finally converged at a shooting protocol in which the first in the sequence was taken at the widest aperture and shortest exposure time to make a sharp core, followed by a sequence of additional exposures made as long as possible by stopping down the lens all the way.
The selected composite frame was taken when some additional light occurred to the background thereby exceeding the dynamic range of the D2X. Processing in Bibble 4 with its peculiar highlight recovery adding lots of colour casts to the recovered areas did the rest.
So, now you all know the recipe for shooting a dandelion ...
« Reply #39 on: June 21, 2015, 21:32:22 »
Well that was close.
You really thew me off by the stating the image as shot as around f/4... :)
« Reply #40 on: June 21, 2015, 21:51:20 »
EXIF is recorded only for the first frame in a multiple exposure .... I started by building from a sharp core, then blurring by the long exposures following the first one.
« Reply #41 on: June 21, 2015, 22:14:53 »
Nikon D2X with the 200-400 mm f/4 Zoom-Nikkor ED.
Exposures around f/4 and 1/1600 sec.
No, this one :)
« Reply #42 on: June 21, 2015, 22:17:18 »
Well as I said: EXIF tells me f/4 and 1/1600 sec. That is what I duly reported.
The 200-400 is of course CPU-modified.
« Reply #43 on: June 23, 2015, 11:10:47 »
Love the image, if I didn't know otherwise, I would likely mistake it for being a painting. Very interesting technique, thanks for explaining it.
« Reply #44 on: August 10, 2015, 09:33:36 »
OK. I did not follow this after my comment.
You did intentionally defocus and/or shoot in wind with a longer time plus you did overexpose to blow out the BG
