Author Topic: !DAILY UPDATES! January. 366 days: your 2016 in photographs  (Read 223870 times)
« Reply #105 on: January 07, 2016, 17:24:39 »
The news related photographs can be found here  http://tilburgers.nl/
« Reply #106 on: January 07, 2016, 17:41:16 »
January 7 2016
Df nikkor 50mm f/1.4ais
Amsterdam this morning
« Reply #107 on: January 07, 2016, 17:51:51 »
A lovely blue Amsterdam, nice Fons.
« Reply #108 on: January 07, 2016, 18:18:36 »
thank you John
« Reply #109 on: January 07, 2016, 20:49:14 »
Very clear and nice air, Fons
Peter Forsell
  • A Cunning Linguist
« Reply #110 on: January 07, 2016, 21:24:57 »
An old elevator.
« Reply #111 on: January 07, 2016, 23:07:58 »
another quick lightning experiment. 55/3.5 + pk13
« Reply #112 on: January 08, 2016, 02:17:42 »
I found this little guy in the backyard.
iPhone image
« Reply #113 on: January 08, 2016, 11:13:07 »
Gary: Caterpillars are happy with the rain? All good or all flood at your place?
« Reply #114 on: January 08, 2016, 12:18:43 »
January 7, 04:05 AM capture of the Catalina comet showing as a blue-green sphere to the lower right. (A tracker would have been necessary to capture the tail). The stripe pointing towards the comet may be a satellite or a meteorite. The comet was found by following the long "tail" of Ursus Major another length down to the the prominent Arcturus star which has a warm color, and then up 2-3 heights of a 105mm (DX) frame and a little to the left. Contrast was challenged by some aurora, seen as green shimmer in the left part of the frame.
NIKON D7100, 105 mm f/2.5 @ f/3.2 , 3s , ISO 3200, single exposure. The comet enhanced with a control point in CNX2, cropped to ce. 1/2 of the frame.
Also in close vicinity yesterday was the diffuse sphere of the M3 galaxy to the right in the image below, and the comet to the left.
NIKON D7100, 105 mm f/2.5 @ f/3.2 , 3s , ISO 3200, single exposure. The comet was enhanced with a control point in CNX2, cropped to ca. 1/2 of the frame.
« Reply #115 on: January 08, 2016, 12:35:16 »
My post for 8 January 2016 is called "old and older" because the huge building is from the 1970ies and the buildings on the right might well be from the 1870ies.
This is a handheld multirow panorama taken with the Fuji X100T this morning and rendered using Autopano Gigs 4.2.2. The original file is H U G E
« Reply #116 on: January 08, 2016, 13:58:14 »
Jan 8 2016
Df 105/2 (d700, 35/1.4g)
« Reply #117 on: January 08, 2016, 14:56:49 »
Finally the sun today.
The terrace-screens of 'Lunchroom' De Ritz, Heuvel in Tilburg
Df  105/1.8
« Reply #118 on: January 08, 2016, 16:34:42 »
All good Frank.  In anticipation of El Niño I installed a rain gutter system. The yard is on a bit of a grade, a retaining wall in the very back, a three foot drop, then a downward slope to the front. Until this year the patio would flood and the areas near the house would swamp.  With the rain gutters and barrels I have significantly reduced the flooding and swamping. I have repeatedly emptied the rain barrel water into the koi pond, potted plants and flower beds. (I have an extensive potted veggie garden all cosy in pots ranging from 1.5' to tree size pots.) I have discovered the need for larger rain barrels.
The caterpillars tend not to feed during the rain. The above caterpillar is a Monarch. We have caterpillars and butterflies all year long. Monarchs, Whites, Sulphurs, Painted Ladies, Morning Cloaks and Swallow Tails are the most common. We've choose many plants based upon butterfly and hummingbird attraction. (We have hummers all year long also.) Often, the Monarch caterpillars will completely strip a Milkweed plant and we have to round-up and move the caterpillars to different Milkweeds.
This was the first El Niño storm to hit Southern California ... Apparently many more are stacked up and making their way across the Pacific. The problem with California rain is the heavens open up and dump everything at once. It doesn't rain very often in Southern California, but when it does it isn't gentle. Combine a heavy rain with a steep terrain (local mountain are approx. 10,000' high), barren foothills (massive bushfires burned all the hillside vegetation) and you have a formula for flooding and mudslides on a Biblical proportion. The flood control channels and rivers are wild and peaking with exploding, brown choppy/churning water. The Los Angeles River is largely concrete and at it's peak was designed to move 146,000 cubic feet of water every second. The Colorado River, sculptor of the Grand Canyon, can't do a quarter of that. California receives about 25% of the annual rainfall of France, but we have twice the amount of flood control.
 After four years of drought, this is a good thing, but be careful for what you wish for.
« Reply #119 on: January 08, 2016, 19:35:42 »
Grey day today. Lumia 930 jpg
