Author Topic: [Theme] Do you have a stitched photo?  (Read 214086 times)
Re: [Theme] Do you have a stitched photo?
« Reply #570 on: September 08, 2020, 22:20:08 »
Wow! Akira and John, great stuff. Panos to show the big vista.
I've chosen differently, using a pano (20 images) to show a seemingly normal view. Went out the other night, this is basically at the back of our residential area, some agricultural fields.
[EDIT: edited to add: yuck, the halo again. It's not there in the original]
« Reply #571 on: September 09, 2020, 12:57:58 »
Thank you, Hans!
Your image looks indeed normal, but the original file should live up to a HUGE print that would look spectacular.
I observe the halo around the trees but I guess that is due to the aggressive compression.
« Reply #572 on: September 09, 2020, 20:32:24 »
Nice one, Hans. IMO, It could be posted at higher pixel dimensions (≈2000x2000?)and still meet the size restrictions of the Nikongear site.
« Reply #573 on: September 09, 2020, 22:34:48 »
Thank you gentlemen! Much appreciated.
I think that there is much halo-ing from compression, but to really get rid of it i have to look at 100%. And, as Akira states, that would mean a huge file, so i'm not sure 2000px would help. I've had this with another pano i posted before (of a London scene) and did a hyper careful re-edit. But, then i loose some of the punch of the photo.
Thanks again for your comments and suggestions!
« Reply #574 on: September 09, 2020, 22:38:39 »
Yet another dawn pano.
« Reply #575 on: September 09, 2020, 22:40:51 »
V1+10mm f2.8 lens
4 portrait images pano
« Reply #576 on: September 09, 2020, 22:43:02 »
Very nice Akira,
By the time you finish shooting did the exposure change much ?
« Reply #577 on: September 09, 2020, 22:44:57 »
5x4 matrix ?
what software ? I can see PS puking something odd with the content on the top right corner
« Reply #578 on: September 09, 2020, 22:53:04 »
Very nice Akira,
Thank you, Armando.  This particular pano consists of only three horizontal frames, and it took only 3-4 seconds to shoot all necessary frames.  So, there was no exposure issue even though, as you assume, the light and color were changing quickly in this time of the day.
A question from me as well: I love the idyllic pano.  I realize it contains foreground.  Did you need to adjust the nodal point and use a tripod to shoot the frames?
« Reply #579 on: September 10, 2020, 02:35:21 »
I shut it by hand, I'm starting to take the v1 on motorcycle rides, small enough to carry in the small bag placed on the tank, which is subject to significant less vibration than anything over the rear wheel
« Reply #580 on: September 10, 2020, 04:37:17 »
Thank you for the details.  Nikon 1 could have been a very promising system.  I truly miss it.
« Reply #581 on: September 10, 2020, 08:10:03 »
V1+10mm f2.8 lens
Pineapple field?
« Reply #582 on: September 10, 2020, 08:23:26 »
Vertical pano. I needed context.
  Last rays window.
 Z6, 135mm 2.8 ai-s
« Reply #583 on: September 10, 2020, 12:29:13 »
  Last rays window.
 Z6, 135mm 2.8 ai-s
Very nice.  I'm fan of your stripped-down concept.
« Reply #584 on: September 10, 2020, 12:53:44 »
Thank you Akira
