Author Topic: [Theme] Do you have a stitched photo?  (Read 213573 times)
Re: [Theme] Do you have a stitched photo?
« Reply #375 on: April 16, 2018, 00:09:23 »
This is a 6-stitch pano.  The frames were taken with iPhone SE, the original DNG files were shot and converted to JPEG in Lr app.  The frames were stitched in Photomerge, and the TIFF file of the pano was adjusted in Camera Raw filter.
The third frame from the left was blurred, but the pano looks good enough for sharing it in Facebook.
« Reply #376 on: April 16, 2018, 05:07:04 »
How appropriate!  It's surprising to know that the giraffe stood still long enough to collect the necessary frames.  Well done!
Thanks Akira, I was a bit surprised too that the stitch worked so well. The giraffes sometime have these long periods where they are mostly frozen and just stand there looking. They must have a pretty good overview from up there.
« Reply #377 on: April 20, 2018, 06:40:11 »
After a hard winter - stitch of 3 horizontal frames with 300 PF:
« Reply #378 on: May 28, 2018, 16:56:38 »
Lorne, Your stitches give a better sense of what the moon looked like than I have seen in 25 years of seeing the NASA single 70mm frames.  Bravo.
 Olé
« Reply #379 on: May 28, 2018, 16:58:23 »
I had to give it a try. El-Nikkor 105 5.6 on a d700. Alhambra from "El mirador de San Nicolás".
« Reply #380 on: May 28, 2018, 18:48:21 »
Nice view!  I realize I haven't tried stitching telephoto images.  I must try for me, too!
Lorne
  • it started with a Nikkormat
« Reply #381 on: May 29, 2018, 01:41:58 »
Here is one from 12 years ago of Victoria's inner harbour. I'd only had my D200 for a few months and, having no means to edit raw I shot only jpegs back then. It is almost a 180° pano, 16 verticals with 50mm/1.8 AIS.
Eagle eyes will spy the Empress Hotel on the far right. It is still with us but Undersea Gardens are just a memory.
« Reply #382 on: May 29, 2018, 03:08:30 »
Love the contrast between the right and left sides of the pano!  The stitch looks flawless.  Did you stitch the images 12 years ago, or right before you post it?
Lorne
« Reply #383 on: May 29, 2018, 04:44:08 »
Thank you, Akira, but all my panos have flaws when you look close enough  ;)
Yes, it's new today and is a favourite pano that I revisit from time to time. I was tidying up some of the rough edges - blotchy skies and zig-zag'd top and bottom edges. Autopano 4.2 is my favourite tool.
In 2007 I used Serif, and since then I've used Canon Photostitch, and Photoshop Elements 6, and PS CS5.
« Reply #384 on: May 29, 2018, 12:16:31 »
Thank you, Lorne, for the details.
When I was using the pano function of PSE, there were still some glitches, but the Photomerge of today's CC2018 does an admirable job.
« Reply #385 on: June 11, 2018, 00:18:57 »
I took the bike fot a tour yesterday to "Punta Europa", backside of Gibraltar. the lighthouse there  and a clear day gives a sensation of Africa being very close. Actually, it is close.
Brute
  • Podunk USA
« Reply #386 on: June 11, 2018, 00:36:22 »
Nice Shots....
First time trying to merge some photos. Had to change the size. The first time said the files were to large. Hope it works now.
The bridge is just a bit down stream of the dam.
Ken Smith
« Reply #387 on: June 29, 2018, 07:09:10 »
Big trees in the front yard. West Los Angeles.
Vertical stitch, three 17mm (on FX) horizontally-oriented frames.
« Reply #388 on: June 30, 2018, 04:02:04 »
From the night to the day...
« Reply #389 on: July 12, 2018, 21:26:40 »
