Author Topic: [Theme] Df (D750)+ Rodenstock Heligon 100mm f/1.6  (Read 143807 times)
Andrew
Re: [Theme] Df (D750)+ Rodenstock Heligon 100mm f/1.6
« Reply #420 on: August 17, 2021, 17:28:11 »
Lily with Z6
Andrew Iwanowski
« Reply #421 on: August 19, 2021, 13:12:58 »
Excellent addition, Andrew!
« Reply #422 on: August 19, 2021, 20:51:18 »
Just what we needed after such a long break, thx for sharing! I really enjoy these a lot - and miss these lenses, I have had several, so nice to see picks from them  ;D
« Reply #423 on: August 20, 2021, 11:43:31 »
Thanks, Erik!
This was your lens and i abducted it  8)
« Reply #424 on: August 20, 2021, 12:48:11 »
Such a treat to see your work again Mr. Jakov!
« Reply #425 on: August 20, 2021, 12:49:17 »
Andrew, striking colors and dreamy shpaes, what's not to like!
Andrew
« Reply #426 on: August 20, 2021, 19:01:30 »
Oh... Thanx a lot!
And few more....
Andrew Iwanowski
Andrew
« Reply #427 on: August 20, 2021, 19:03:05 »
I hope I am NOT trespassing on Jacob sunflowers domena.....
Andrew Iwanowski
« Reply #428 on: August 21, 2021, 00:11:15 »
Not at all, Andrew. Great results, keep posting!
Thank you, Mr. Paco!
« Reply #429 on: August 21, 2021, 01:43:45 »
Thank you, Akira.
Mini roses.
Love this dreamlike one!
Lily with Z6
Elegant and pretty at the same time.  Nice!
« Reply #430 on: January 09, 2022, 16:12:53 »
Lest we forget, the Rodenstock behaves quite differently on the Z system cameras. Infinity focus is a breeze.
« Reply #431 on: January 09, 2022, 16:54:12 »
Adapting the Rodenstock 100/1.6 to the Z system is very simple. I just added a 65-65mm helicoid (17-31mm extension) with a Z mount on the rear end and a 52mm thread in front, since my Rodenstock already had a 52mm thread adapter fitted. Alternatively, I could have used the rear stock threads on the Rodenstock which I believe are 2" (48mm).
« Reply #432 on: January 09, 2022, 18:58:58 »
It looks simple.
But I made the most fatal error possible.  I glued the mount on the wrong side of the helicoid.    Nothing is possible any more.  The glue is too strong to correct the error.  And it is not possible now to connect the lens, to the moving part of the helicoid...
 I gave up...
« Reply #433 on: January 09, 2022, 20:21:59 »
Tried heating in an oven at say 200C? Most epoxy glues break at high temperatures.
Murphy's Law applies when the number of options >1.
« Reply #434 on: January 09, 2022, 20:36:48 »
I tried that before.  Will give it another go.
