Author Topic: [Theme] Df (D750)+ Rodenstock Heligon 100mm f/1.6  (Read 137399 times)
charlie
Re: Df + Rodenstock Heligon 100mm f/1.6
« Reply #165 on: November 01, 2015, 21:34:20 »
On topic but off topic, how is everyone mounting their Rodenstocks? Care to share pictures of the modified lenses?
I'm grinding out a very thin Nikon F to M42 adapter that I was planning to epoxy to the lens, trying to keep as long a focus distance as possible. Before applying the epoxy I thought I see what others are doing.
stenrasmussen
« Reply #166 on: November 01, 2015, 22:30:33 »
An empty 18-70 houses it well.
« Reply #167 on: November 01, 2015, 22:57:01 »
The 100 mm f/1.6 is very simple to adapt to F-mount. Add 52 mm threads to it for example by using a Cokin filter adapter that has the suitable threads.  Then, add K-rings to act as spacers, and put a K-2 to the other K-rings to provide the camera mount. In the picture below, K-2, K-4, and K-5 have been used. Additional K-rings will allow the lens to focus closer.
Mikes
« Reply #168 on: November 02, 2015, 02:40:00 »
This is the result of the approach I took using a T-ring to Nikon adapter - as described in reply #33.
Mike Selby - Sydney
« Reply #169 on: November 02, 2015, 16:52:28 »
My Heligon has a connection like Bjørn describes.
A kind of white flower,  perhaps appropriate on All Souls' Day...
« Reply #170 on: November 03, 2015, 15:58:25 »
This is definitely the Heligon 100/1.6  with the Df   ;)
« Reply #171 on: November 03, 2015, 16:06:26 »
John, it definitely is!  8)
Björn Carlén
  • Errare humanum est
    • flickr
« Reply #172 on: November 04, 2015, 11:09:26 »
How do you mount the filter adapter on the lens tube?
And, is the K-2 safe to use unaltered on a modern body?
Björn Carlén
Huddinge, Sweden
« Reply #173 on: November 04, 2015, 13:31:31 »
Usually the 52 mm thread supplier (Cokin or similar) can be seated against any convenient flange along the rear lens casing. Most of these lenses appears to have a step-ladder like profile, so the threads will find a final home somewhere. Exactly where is immaterial as you just add more spacers if necessary.  Fix permanently into position by small screws or judicious application of epoxy glue. Just ensure the threads stay clear of any glue residue and all is well.
Photo below should illustrate the basic concept (sorry - old photo and I just realised it isn't sharp at all, but should show what you need to know anyway).
I have used K-2 on all models of modern Nikons without encountering any problem, so that is what I would describe as 'safe mounting' in my book.
Björn Carlén
    • flickr
« Reply #174 on: November 04, 2015, 13:45:00 »
Thanks, Bjørn Rørslett!
Very informative.
Björn Carlén
Huddinge, Sweden
« Reply #175 on: November 04, 2015, 13:58:39 »
The remains of the Dandelion (or it's family?)
« Reply #176 on: November 04, 2015, 14:37:06 »
John is on a role :)
« Reply #177 on: November 04, 2015, 16:06:12 »
Thanks Jakov. It's good to illustrate the Heligon's qualities, I think ;)
« Reply #178 on: November 04, 2015, 17:11:14 »
I stated this years ago, in my article on "Need for Speed", but bears repeating.
When there is no aperture, and [in principle] no means of focusing, all that remains is to make the image.
« Reply #179 on: November 05, 2015, 19:25:33 »
Yes, sort of  ;)
