Author Topic: Nikon, why no "Monochrome" digital camera?  (Read 12252 times)
BruceSD
  • Confirmed Bokeholic
    • The F/2 Guru
Re: Nikon, why no "Monochrome" digital camera?
« Reply #15 on: November 25, 2025, 03:34:43 »
From my limited experience with my new Pentax K-3 iii monochrome camera I can say:
1. The same lens (Zeiss ZF 25mm f/2.8 at f/8) on the 25mp Pentax monochrome produces images that are much sharper than those I get from that same lens on my 42mp Z7 body.  Same sensation I had when I first went from shooting regular digital images to shooting pixel shift images on the same digital camera.  The difference was obvious and powerful.
2. I've made many digital black and white images from files captured by my color digital cameras.  The middle grays and tones are clearly better from a true monochrome sensor.
3. Those of you who have not actually used a monochrome digital camera may not understand the significant increase in image quality a monochrome sensor camera provides over B&W images captured by a color digital camera. Try it, you will not believe the difference.
If you want to find out more about the affordable Pentax monochrome camera, check out this group  -  https://www.pentaxforums.com/forums/219-pentax-k-3-iii-monochrome/
« Reply #16 on: November 25, 2025, 13:52:01 »
Ay, Bruce. My take on the issue is the following:
A "pure" Monochrome Sensor" features the same sprctral response curve as the silicon itself (see attached graphics) and has to be adjusted to taste. A stacked color pixel true sensor allows you to "create your own film"
So what do I want? I want a "Monochrome mode" on my camera that delivers a nice film look and with the Zf I get a exactly that and use it often
However it was achieved, I really like the B&W image you attached to your post Frank
« Reply #17 on: November 25, 2025, 16:21:06 »
Thank you. At f/1.0 the DOF is a tad on the shallow side for the scene
« Reply #18 on: November 25, 2025, 16:23:46 »
Please post comparsion shots
BruceSD
    • The F/2 Guru
« Reply #19 on: November 25, 2025, 22:13:48 »
Sure, but will be a few days/weeks as I'm super busy....
« Reply #20 on: November 26, 2025, 15:28:43 »
Removing the colour filters reduces light loss, but that does not change dynamic range, because dynamic range is full well capacity minus the noise floor = dark noise plus read noise. If the highlights are not clipped, you can use the light not being lost to the colour filters to increase exposure, and then you get less noise in the shadows just above black. But you could do the same thing by using a larger aperture or a slower shutter speed. Conversely, if the highlights are already clipped, and you care about that, you have to reduce aperture or use a faster shutter speed to compensate for the extra light and you don't get the reduced shadow noise. So the conditions under which the extra light is useful are limited.
I was referring to the situation where one photographs people in available light indoors, which is a situation where the scarcity of photons and color spectrum of the light sources are key limiting factors to image quality. You cannot use a larger aperture if you are already wide open and using a borderline slow shutter speed where the slightest subject movement would cause significant blur. This is a very common situation in indoor or night time events. Highlight clipping is not a priority if the subject faces are excessively noisy in the resulting images due to the lack of adequate photons. Reducing the attenuation due to the CFA would alleviate the situation somewhat, arguably significantly. Faster lenses (such as f/0.95, f/1.2 etc.) also have the problem of excessively shallow depth of field in many cases, large weight etc. and high cost, and lack of the ability to zoom which is a serious limitation in many types of event photography. I've sometimes had to go as high as ISO 102400 to register an image at f/2.8 (granted, it was deep inside medieval castle ruins, but there were some artificial lights used by the dancers). In wedding photography I routinely have situations where I am at ISO 25600; I'd much rather have the image quality of ISO 6400 or 12800 and keep the aperture and shutter speed I get from ISO 25600 in those situations. Despite the high sensitivity of cameras such as D6, there are still many situations where there is not enough light for a good enough image and which could be improved.
The increase in resolution with a monochrome sensor is small.
I agree but if the file size and processing times are considered significant limitations, the designers could triple the number of pixels of a monochrome sensor while retaining the same file size as a color sensor camera without imposing a significant penalty on file storage or processing time (raw conversion would be significantly faster than today, which is another advantage). And then the image resolution would be greater.
One reason is that the Bayer process is the process of human vision, and our brains use luminance for detail and add a rather crude colour map on top of that. If you look at the limiting resolutions (MTF50) measured by target reproduction photography and compare them to the Nyquist limit that is the maximum benefit you can get, and with current equipment it is remarkably small. Then there is the fact that ink jet printers are limited to 260 or 300 dpi = 10 or 12 per mm, so the most they can print is 5-6 lp/mm. If that is achievable with a Bayer sensor and a good lens you don't get any benefit of a monochrome sensor's higher resolution in the print.
Yet it's plainly very obvious how the image detail created by resampling from an 8K sensor to a 4K final image results in a noticeable improvement in image detail over a native 4K sensor. This wouldn't happen in the absence of the CFA and possible AA filter. Of course, if aliasing is a problem, then I refer to the above proposal of increasing the monochrome sensor pixel count by a factor of three to reduce the effects of aliasing while retaining the original file size.  This is very obvious when inspecting video from native 4K and 8K cameras at 4K resolution.
Where is your inkjet limitation coming from? My Epson P900 prints at 5760 x 1440 dpi. Some landscape photographers using medium format have suggested that improvements are visible up to about 1000 ppi when printing. Others can't see much due to aging vision or otherwise poor eyesight. Personally since I don't use glossy paper, I haven't gotten into such comparisons; matte and semiglossy papers don't show as fine details as glossy. But anyway if the print size is large (or there is a need to reframe by cropping) then there is plenty of opportunity to benefit from higher resolution and MTF.  (For landscape, I wouldn't personally be using a black and white sensor.)
Les Olson
« Reply #21 on: November 27, 2025, 11:24:42 »
The limit of printer resolution is how small the steps of the paper and the nozzle carriage can be. Printing at 5000 dpi on the long axis would require the steps of paper movement to be 5 microns. They aren't and to the best of my knowledge, they can't be. The drops coming out of the nozzles can be as small as you like, which is why you can have so many dpi, but that isn't increasing resolution.
The limit of human vision is about 10 lp/mm, given excellent lighting and high contrast - and no refractive error - so 5-6 lp/mm for a photograph is plenty.
« Reply #22 on: November 28, 2025, 05:05:47 »
I have noticed over ≈15 years of inkjet printing at home with Epson pigment printers that, at least under my command, the inkjet printers cannot reproduce the sense of "sharpness" and detail one sees in a 8x12cm image printed in a good photo book made by conventional lithography.  There seems to be limit to inkjet that is exceeded by other systems.  Another example of a medium that exceeds inkjet would be contact prints from 8x10 inch film. The smaller the inkjet print, the more obvious the detail deficit is, assuming the original image has lots of detail.
Les Olson
« Reply #23 on: November 28, 2025, 12:07:46 »
The sense of falling into a well of detail you get from an 8 x 10 contact print is something too few people experience. Slow B&W film can record 100 lp/mm, and although paper cannot quite match that, a contact print can exceed by several times the limit of human vision. The awareness of detail you can't see is, IMO, a big part of the magic of large format photography.
« Reply #24 on: November 28, 2025, 12:14:21 »
I never said that the printer 5000 dpi along the long axis; in the 1440x5760 figure, the first figure is along the direction of roller movement, the second along the direction of lateral movement of the print head (the relationship to long and short dimensions are unclear if roll paper is used). Since the printer lays out ink over a width of the paper in one pass using a matrix of nozzles and then moves the paper a bit and lays out another layer of ink with partial overlap, I'm not sure if it is necessary to move the paper in steps corresponding to the resolution of the image details along the long dimension of the paper, it could lay out finer details than the roller step size by using the nozzle matrix - at least in theory. I don't know if this is the case though.
Here is some testing of the print resolution at different input resolutions (and printer settings), using Epson Ultra Luster Paper:
https://www.printerknowledge.com/threads/star-chart-resolution-tests-of-the-epson-p900.16920/
The authors conclude that "From these tests, I concluded that, for my needs, using 720 Image PPI and the 1440x1440 print quality setting was a good choice. This setting provided a decent increase in resolution while enabling the full P900 resolution at the cost of 4X the image pixels. I would use 720 Image PPI and the 1440x5760 print quality setting if, in rare cases, the image justified a slight resolution or edge quality boost. The small increment in resolution for a portion of the angular space with an Image PPI of 1440 did not seem worth another 4X total image pixels."
720 ppi = 28 pixels per mm which can reproduce at most 14 lpmm was concluded a good choice for the source image, although in some cases a higher resolution of the source image (1440 ppi) produced slightly more resolution along some angular directions, but this was not considered worthwhile by the author. But clearly if we are talking about the limitations of the printer, the source material should be of the highest quality.
Glossy paper is likely to be somewhat better in reproducing fine detail than luster, but I haven't used it on the P900 and that was not tested in the above article.
Even if some print-making techniques produce more detailed or sharper small prints than a P900, for me this has not been an issue. Having the fast turnaround (a few min) and control afforded by having all the equipment to edit the image and make prints in one place along with free choice of print size (up to A2 in my case), the high maximum density of inkjet prints, and excellent light permanence of the prints means I basically never source out printing of my images, though I recommend people to have commercial labs do the thank-you cards because type C paper has better handling and wet resistance than the inkjet prints so they are more likely to survive handling by the postal service. If I need to make larger than A2 prints, then of course I source out, but that's not typically the case. I've never been happy with the print to screen matching of commercial labs and I've had so many quality issues with them that I can't imagine making prints if I had to outsource them on a regular basis. It would throw away any joy I have from photography and cause so much frustration.
« Reply #25 on: November 28, 2025, 12:18:45 »
Few books unfortunately have high print quality, in my experience, most show some visible raster in the image, and some friends of mine who have had their photography printed in a book, have complained about the color matching as well. I by far prefer the inkjet prints to the print quality of books. Perhaps I just haven't seen well-printed books.
JJChan
  • JJ Chan
« Reply #26 on: November 28, 2025, 14:10:07 »
Not sure this adds much and no way as technical as Bob Friedman's converted D850 shots, but a few from a morning walk in Fremantle with borrowed M10M and Leica 35mm FLE. I wish I could afford the combination.
JJChan
  • JJ Chan
« Reply #27 on: November 28, 2025, 14:25:42 »
And same day with Nikon F6 Ilford XP2 and AF-S 35mm f1.4G
« Reply #28 on: November 29, 2025, 05:42:52 »
B&W is more likely to look good in books than color, but still seems to require a commitment to high-end printing by the publisher; of course color adds color hue rendition issues.  On the other hand, way back in the 1990's I had a friend that would shoot snapshots on 35mm color neg film, and then take the 4x6" machine prints to the local color Xerox shop and have 8x10" color Xeroxes made. Everyone loved that they were on plain paper, had exaggerated color saturation, blobby low resolution and being ink, didn't have the plastic "RC color photo paper" look.
Macro_Cosmos
    • Flickr
« Reply #29 on: December 02, 2025, 07:37:27 »
Simply because there is no market for it and monochromatic cameras will always be more expensive due to that.
It does have benefits: more light, more resolution and higher QE%.
For the purists, more "pure" in a sense, too.
The downside is obvious.  To get a colour image, you will need RGB filters.  You need high-quality bandpass or even narrowband interference filters.  These are often over $400 (Semrock) or $200 (optolong) a pop.  For a set of three, you are looking at upwards of $1500.  Mind you, these are only 25mm in diameter.  Now imagine how much a 52mm one would cost.  What about 77mm?
https://www.idex-hs.com/store/product-detail/af01_551_22_25/fl-433417?cat_id=semrock_optical_filters&node=individual_optical_filters
Therefore, the only economically feasible option is to install it in front of the sensor.
Now you have introduced a ~10mm thick piece of glass.  Whoops, you have to alter your lenses slightly to compensate for the extra path length, or else the lenses will be soft -- what is the point of monochromatic cameras again?  Time to introduce a special class of lenses that nobody would buy.
Would you trust the user to install something right in front of the sensor?  Time to increase the price to compensate for the extra RMAs due to stupidity.
So the conclusion is simply forget about colour images.  Will you miss them?  Yes, you will.
There is just no market.  It is more feasible to convert a camera to monochrome.  The bayer array can be scraped off with a bamboo chopstick.
These cameras are particularly useful for scientific imaging and deep space astrophotography.
For example, you can view JMC's extensive gallery of diatoms here: https://diatomimaging.com/gallery1/
He uses a BW converted Nikon D850 camera.  I was told that he uses jpegs straight out of the camera.
I have some as well.  These were captured with a Hamamatsu camera.  The colour image was a blend of RGB stacks.
(I really wish we could get square sensors on normal cameras.  Modern lenses can fill them well, and it will offer greater cropping capabilities.)
If you are interested in monochromatic conversions, a D5100 running Nikon Hacker firmware would be solid.  I am thinking about potentially offering converted cameras for sale but the amount of pre/post-sales work puts me off.
Blog: Diatoms Australia
