Author Topic: [Portfolio] Floating hide in August  (Read 4104 times)
Joost Bollens
Re: [Portfolio] Floating hide in August
« Reply #15 on: September 08, 2025, 09:23:01 »
I would be a bit nervous about bringing all that expensive equipment in such close contact with water without further protection like a waterproof housing...
Thank you for your appreciation! As to the dangers of not having further protection, I guess that especially during the loading and unloading phases you have to be attentive: as long as the lens is not attached to a gimbal head, a lot can happen, and indeed the surface under water can at times be slippery. But once attached, I found it to be a rock solid solution.
Of course, it's best to check carefully that everything is securely fastened.  I learned that the hard way a few years ago when I attached my D600 with a 17-35mm f/2.8 lens onto my tripod head, or so I thought. When I turned around, I saw, as if in slow motion, the combination fall to the ground and then spin down, straight into a pond. Since then, I tend to double-check the connections.
Incidentally, both the camera and the lens survived.
mfilippa
  • You ARE NikonGear'23
« Reply #16 on: September 08, 2025, 09:28:12 »
Great job!
What the next step: a submarine with his periscope?
Beautiful shots
Mario Filippa
Joost Bollens
« Reply #17 on: September 08, 2025, 09:33:12 »
And also to Arturo, Birna, Tim, Bent, Paco, Ann, Fons, and Mario: thank you for your kind words!
« Reply #18 on: September 08, 2025, 10:18:09 »
A lot of perseverance should be required.  Great series!
« Reply #19 on: September 08, 2025, 10:54:28 »
Superb, Joost !   Impressive series !!
Thomas Stellwag
« Reply #20 on: September 08, 2025, 13:35:19 »
excellent pictures you show here from an unusual prespective. Looking at them, I imagine I feel your patience to get them.
Thomas Stellwag
« Reply #21 on: September 08, 2025, 15:05:21 »
+1
Great reward here for your efforts.
« Reply #22 on: September 08, 2025, 16:58:23 »
Superb images, Joost.
Joost Bollens
« Reply #23 on: September 08, 2025, 22:22:07 »
@ Akira, John, Thomas, Hugh and Bruno: thanks!
Patience? In fact, the hardest thing was getting out of bed at 5 a.m. for several days.
Once you are in the hide, time flies.
Nasos Kosmas
  • Athens, Greece
« Reply #24 on: September 08, 2025, 23:56:50 »
 Excellent captures Joost :)
It must be very interesting to have all this wildlife near you!
Keep on!
« Reply #25 on: September 09, 2025, 13:30:48 »
Wonderful photos, fully justifying your efforts to get down to water level.
Ian Watson
« Reply #26 on: September 09, 2025, 15:26:33 »
Magnificent, Joost! Thank you for the insight into your methods and for sharing your results.
