Author Topic: May 2025  (Read 26893 times)
Hans_S
  • Melbourne, Australia
Re: May 2025
« Reply #255 on: May 26, 2025, 03:02:38 »
wow - what a contrast
High tech silicone vs oil on canvas. I do like how the curators have chosen to lighten up the gallery spaces normally filled with the "dark 'n' gloomy" oils.
Hans Schepers
Hans_S
Re: May 2025
« Reply #256 on: May 26, 2025, 03:11:43 »
Akihabara, Tokyo.  Shot with Leica LUX app in iPhone 14.
I like the sense of motion and how the two pedestrians "bookend" the third one with the cat on a leash...I presume they're heading for the Cat Cafe. ;)
Hans Schepers
Adli Wahid
Re: May 2025
« Reply #257 on: May 26, 2025, 04:39:48 »
You power the D700 to great heights, Adli !!
Thank you John. The D700 has been a loyal and reliable travel companion :-)
Re: May 2025
« Reply #258 on: May 26, 2025, 10:01:40 »
Glad you like it, Hans!  FWIW, it's a dog.  He would be seriously in trouble if he would enter the cat cafe...
  • Fairbanks, Alaska
Re: May 2025
« Reply #259 on: May 26, 2025, 10:44:59 »
Sunspot active region AR4079 has just made it back from its round at the back of the sun. Visible at the upper left, it still consists of two subregions with a brighter divide in between. It will be worth watching in the coming week (with solar protection). 500PF+ TC-20E III and Baader AstroSolar film ND 5.0 on ASI678MC, stitch of two stacks, each the best 15% of 1500 frames captured in 12-bit mode. Open in new tab for larger version.
Re: May 2025
« Reply #260 on: May 26, 2025, 13:39:44 »
Landscape with rye
Lower Bavaria
Zf  -  Z35mm f/1.8S
Re: May 2025
« Reply #261 on: May 26, 2025, 13:57:25 »
"If You Can't Talk About It, Point to It" (Laurie Anderson)
left combo: from 2.50m to infinity
right combo: from 2.20m to 30m
Thank you, Jürgen.
I got the part: "shorter object distance with extension and not infinity focus"
I did not get the part: "The 300PF is not 300mm focal length if you focus closer"
... I understood this was the case with Micro-Nikkors that have a built in extensioin like the 60mm Af-S
 ... what is the problem with the PF in technical terms?
Re: May 2025
« Reply #262 on: May 26, 2025, 14:00:26 »
500PF+ TC-20E III
I missed the introduction of the Nikon-F-Teleconverter TC-20 III ,,, I still got the II-Edition  and I am not happy with it. I am very happy with the TC-14 III though.
Can you write a short review, please?
Best
Frank
Re: May 2025
« Reply #263 on: May 26, 2025, 14:02:54 »
Nothing special. Just your ordinary Shoten Z to F adapter, MIREX Nikon F to Hasselblad V Tilt/Shift adapter, some Hassi extensions and Zeiss Sonnar 150mm at the far end  :)
What every housefive might easily find in the kitchen drawer...
 ;D ;D ;D ;D
Re: May 2025
« Reply #264 on: May 26, 2025, 14:35:23 »
After testing D850/Zf/D500 with & without extension I still love the D500 + TC-14 II + 300PF with no extension best. The extension slows down the aim-and-shoot significantly.
This combo, right now. 100% PS JPEG-Quality set to 10/12.
Second pic is the D850 taken yesterday, reduced to 40%
Øvind: mouth watering the 4.5/400 on a Z extension
aerobat
Re: May 2025
« Reply #265 on: May 26, 2025, 15:50:49 »
Capturing light, but also recognizing who’s the biggest painter… marvelous Daniel!
Many Tanks John and Jan
Daniel Diggelmann
Jürgen Pfeiffer
  • You ARE NikonGear'23
Re: May 2025
« Reply #266 on: May 26, 2025, 16:30:56 »
Landscape with rye
Lower Bavaria
Zf  -  Z35mm f/1.8S
Keep it simple!
I love landscapes like this, and especially this pic.
Jürgen Pfeiffer
Adli Wahid
Re: May 2025
« Reply #267 on: May 26, 2025, 16:53:01 »
Practical use of rickshaw in Dhaka, Bangladesh :-)
Nikon D700 + Nikkor 28mm 2.8 ais
Re: May 2025
« Reply #268 on: May 26, 2025, 17:00:33 »
Thank you Jürgen
BL
Re: May 2025
« Reply #269 on: May 26, 2025, 19:53:36 »
If you start thinking about this lens even for the shortest moment you are definitely lost :) It is sort of expensive, but also kind of essential, you won't regret the decision.
And now for something completely different: another Scheimpflug solution with almost striking elegance.
Thanks Jurgen! The Z 400mm f/4.5 VR S plus tc-1.4 x is at home now. Thanks for pushing me over the decision line! It’s indeed amazing!
Jan Blomberg
