Author Topic: May 2025  (Read 63875 times)
Re: May 2025
« Reply #180 on: May 20, 2025, 20:41:03 »
Infra Blues
Re: May 2025
« Reply #181 on: May 21, 2025, 00:20:40 »
Three little maids [from school we are]
IR version
Re: May 2025
« Reply #182 on: May 21, 2025, 09:10:56 »
 ;D ;D ;D
Alas, yes. The lovely optics in the Zf's viewfinder mean that I can fiddle with menus and review images without juggling my glasses.
On the bright side, I can still count the hairs on a fly's arse at distance  :)
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: May 2025
« Reply #183 on: May 21, 2025, 12:25:39 »
It is a flower from a Murcian garden.
ARTUROARTISTA
    • APM Pintor
Re: May 2025
« Reply #184 on: May 21, 2025, 12:31:50 »
Birna, if the photo is not correct, delete it, I mean because of the size.
Re: May 2025
« Reply #185 on: May 21, 2025, 12:53:24 »
More students getting graduated. This time from the flamenco side. The picture was taken at the Falla Theater in Cádiz.
  D5, 58mm 1.4g
Re: May 2025
« Reply #186 on: May 21, 2025, 13:28:13 »
File size is OK  but try to use a lower pixel size ;)
Most viewers benefit by slightly lower pixel numbers, but better jpg rendition. Use 1500-2000 pix max on the long side and then jpg level 10-12 usually will keep the file storage size less than 2MB. We want better quality in the rendered web image, not bigger image sizes (pixel dimension) since the latter always will require more hash jpg compression.
Re: May 2025
« Reply #187 on: May 21, 2025, 13:41:06 »
Serene.
You have put the 58mm f/1.4G to good use here.
  D5, 58mm 1.4g
Re: May 2025
« Reply #188 on: May 21, 2025, 16:22:25 »
At the station of Iidabashi, Tokyo.
Thomas Stellwag
Re: May 2025
« Reply #189 on: May 21, 2025, 16:27:01 »
I like these 3 different light colours, each in its own line
Thomas Stellwag
Thomas Stellwag
Re: May 2025
« Reply #190 on: May 21, 2025, 16:28:39 »
  D5, 58mm 1.4g
I am not sure what/who is best in this picture: the lens, the model or the photographer. I tend to say all are very good.
Thomas Stellwag
Re: May 2025
« Reply #191 on: May 21, 2025, 17:40:22 »
A very good evening picture
Re: May 2025
« Reply #192 on: May 21, 2025, 23:59:55 »
Thank you Hugh, Thomas
Re: May 2025
« Reply #193 on: May 22, 2025, 00:00:52 »
Team effort to the light
Re: May 2025
« Reply #194 on: May 22, 2025, 00:11:14 »
Thank you, Thomas and Bent!
