Author Topic: Nikon D1x with green filter?  (Read 16888 times)
Re: Nikon D1x with green filter?
« Reply #15 on: March 13, 2025, 18:55:54 »
The 'standard' green photograph (1) seems to contain more details than the White balance corrected one (2) (pre defined based on photo)
« Reply #16 on: March 13, 2025, 18:59:53 »
Both transferred to black-white in Photoshop based on the green white balance (3) and the adapted White Balance (4)
« Reply #17 on: March 13, 2025, 22:44:45 »
What about updating the firmware for the camera?
« Reply #18 on: March 14, 2025, 05:06:39 »
Sorry to say, there could be the hardware problem like significant loss of gain on the red channel for some unknown reason....
« Reply #19 on: March 14, 2025, 08:22:34 »
Firmware 1.1
« Reply #20 on: March 14, 2025, 08:24:30 »
I think it's not a hardware problem.  The camera functions, apart from the green filter, perfectly.
I think some-one opened the camera and inserted a green filter in front of the sensor.  Probably to use the D1x for Black-and-white photography. a l
In camera it's possible to change the fileoutput to Tiff and change the B&W processing in which case you get a large file of 16mb and B&W only.  But in camera you see the B&W effect.
Other option is to do the B&W processing in Photoshop and keep the color raw. (NEF)
« Reply #21 on: March 14, 2025, 10:09:33 »
Couldn’t you see the green filter by looking at the sensor?
« Reply #22 on: March 14, 2025, 14:50:47 »
Thanks for the suggestion Bruno.
Had to use the AC/Adapter to open the mirror.  Compared the 'green' sensor with another 'normal' D1x.
« Reply #23 on: March 14, 2025, 19:33:22 »
The green outcome.
At a light back-ground.
« Reply #24 on: March 14, 2025, 20:01:14 »
With the AF-S 300/4
First one: White balance corrected basically eliminating green and increasing some yello
Second: Auto BW in Photo-shop
« Reply #25 on: March 14, 2025, 20:02:54 »
Both with AF-S 300/4
First one: Uncorrected White Balance
Second One: In camera set to TIFF and B&W processing
