Author Topic: AI Illustrations as a Camera  (Read 10462 times)
Re: AI Illustrations as a Camera
« Reply #15 on: February 02, 2025, 18:19:18 »
Can you call it a photograph if no camera has been involved at any time?
Then you could start in a drawing or paint program with a white sheet and define each pixel by hand (it will take some time).
There is a finite number of "photographs" possible.
I have attached one of them just to push it to the extremes.
Is this a photograph and if it is not why are the AI-generated photographs?
Is it just if you accept it as a photograph when you look at it?
My personal opinion in the moment is that a camera has to be involved but it can be difficult to prove if it is the case. I may change my opinion at some time.
Using a camera some very abstract photographs can be made. It is just light that has been captured in some way.
« Reply #16 on: February 02, 2025, 18:56:48 »
If the implication of 'using a camera' means an optical system records an image, it is entirely feasible to make a photograph without a camera. Or even AI :)
This is an image obtained by using neither camera nor lens ....
« Reply #17 on: February 02, 2025, 19:04:54 »
If it is not a camera then it is not capture of light?
Mathematical formulars, algorithms etc. can generate digital images.
Random numbers.....fractals....etc.
« Reply #18 on: February 02, 2025, 19:09:46 »
« Reply #19 on: February 02, 2025, 19:25:48 »
The image is definitively a record of a light field, and in facts depicts a natural fractal phenomenon. It is NOT generated by any mathematical equation.
Neither a traditional camera nor a lens was used.
« Reply #20 on: February 02, 2025, 21:06:45 »
Ok, if it is a record of light then you can probably also define the "camera" at an abstract level?
Display of recorded light is a photograph?
« Reply #21 on: February 02, 2025, 21:59:15 »
'Photograph' as it is made by light striking a recording surface ....
Ann
« Reply #22 on: February 02, 2025, 22:18:30 »
AI will be much used for Illustration; especially illustrations for Advertising which attempt to pretend to be real photographs.
At the moment the tell-tale signs of the use of AI-generated images are seen in images of hands, feet, skin-texture, eyes and are clearly obvious in the unmatched lighting in different parts of the composite. This will improve with time.
My personal view is that I only want to use photographs which I have shot myself so I have never bought Stock photographs.
I may use AI techniques and editing to combine a better sky or background with a foreground object but all of the components of the final images will have been generated by my own cameras.
