Author Topic: January 2025  (Read 68345 times)
Re: January 2025
« Reply #90 on: January 10, 2025, 22:58:19 »
January 10
At the Windmill 'De Nijverheid' from 1857 in Ravenstein a natural bakery for sourdough bread.
Zf   Viltrox 16mm f/1.8
settings within DxO 8 called lut grading cause banding
Probably could be used to produce excellent rainbows with some additional tweaking?
On a tangential note, I sometime get similar respnse when shooting some lenses through triple-layer windows panes  with my IR camera(s):)
Re: January 2025
« Reply #91 on: January 11, 2025, 01:01:41 »
Interesting piece at the local museum, the image is on multiple glasslayers , so the different distances cause the out of focus areas
x-t3 56mm f/1.4
Re: January 2025
« Reply #92 on: January 11, 2025, 01:16:54 »
Photography as a pedagogic tool.
  D5, 24-70 2.8 vr shooting; Z9, 70-200 2.8 fl on the image
Re: January 2025
« Reply #93 on: January 11, 2025, 04:11:02 »
Out skiing with the dogs.
(Z8 with 40mm f2)
Re: January 2025
« Reply #94 on: January 11, 2025, 10:20:58 »
x-t3 56mm f/1.4
Interesting composition Armando
Re: January 2025
« Reply #95 on: January 11, 2025, 10:26:29 »
These LUT settings seem to push certain colours extraordinarily hard!
Re: January 2025
« Reply #96 on: January 11, 2025, 10:27:40 »
January 11
sheep in the mist
Zf  -  35mm f/1.8S
Re: January 2025
« Reply #97 on: January 11, 2025, 11:58:32 »
This morning - early - and also the "solution" to yesterdays minimalistic enigma.
Re: January 2025
« Reply #98 on: January 11, 2025, 14:01:43 »
Awesome dynamics
I'm curious,  do you carry 2 70-200 lenses,  and 2 large cameras back and forth?
Re: January 2025
« Reply #99 on: January 11, 2025, 17:20:39 »
It is getting colder
This image gives me so much pleasure.
A sense of movement, a feeling like it might have been taken on old b&w film
(unlike so many modern conversions from a colour digital image)
Quote from: Frank Fremerey
Snow continues
I like this one, but for different  reasons.
It feels like a tilt/shift lens has been used because of the well behaved vertical edges of the buildings.
Personally, I'd have wanted more warmth in the masonry (as in Birna's image #msg204668),  but i guess this reflects how it felt that day!
Re: January 2025
« Reply #100 on: January 11, 2025, 17:27:37 »
Weve had temperature inversions several times over the past week.
So the drive to our local hills is done throug murky, misty roads.
But when we climb the hills and get high enough, a golden view with blue skies often awaits us
A nice low sun brings out some nice detail here
(Sadly I only had my smartphone, so this is a heavy crop.
It really needed my 300mm)
KarlMera
Re: January 2025
« Reply #101 on: January 11, 2025, 17:44:02 »
Fairy tale
Re: January 2025
« Reply #102 on: January 11, 2025, 22:53:30 »
January 11
sheep in the mist
Zf  -  35mm f/1.8S
  I'm enjoying this image and the one posted in the "minimalist" thread very much Fons. Sometimes is not easy to recognize your signature but I have realized with time that it is because you have quite a extense arc of possibilities, but it is clear. Thank you for your constant work and for sharing them all.
Re: January 2025
« Reply #103 on: January 11, 2025, 23:08:41 »
Awesome dynamics
  Thank you Armando. Carrying 2 large bodies, a 24-70 and a 70-200 is quite normal for rehearsals and shows alike. It covers a lot of ground with flexibility. Usually 2 batteries per camera. I'm going to attach a photo of the backpack with the gear I selected for this and a weekend in La L'inea. 28 f2-cpu-, 35mm 1.4 ai-s, 60mm macro and 105 2.5 -cpu- with a blackrapid and a gps module for the foolography.  There is s a different selection for video and a light edc that goes "as the wind blows"  ;)
Re: January 2025
« Reply #104 on: January 12, 2025, 09:23:19 »
Paco is a strong guy :) When I arrive in Spain necxt time (Feb./March), I ewon't need to bring my Z9 for Paco to use -- now he has his own !!
