Author Topic: December 2024  (Read 64623 times)
Re: December 2024
« Reply #240 on: December 30, 2024, 01:51:22 »
Foggy
D4s 24-70/2.8G
  Lovely ambiance with mystery
Re: December 2024
« Reply #241 on: December 30, 2024, 12:29:49 »
Engelberg church - Zf & Z 35mm 1.8
The 35mm f/1.8 proves to be an excellent companion for the Zf despite reports considering it the least of the Z lenses?
Re: December 2024
« Reply #242 on: December 30, 2024, 12:33:50 »
More mist from the winter '24 period!
Zf  -  Z 105mm f/2.8S
aerobat
Re: December 2024
« Reply #243 on: December 30, 2024, 18:06:11 »
Many thanks Fons - yes it is very good - all is relative and despite being probably one of the best 35mm ever, it is a bit weaker compared to the other Z primes.
Daniel Diggelmann
aerobat
Re: December 2024
« Reply #244 on: December 30, 2024, 18:07:04 »
Zf  -  Z 105mm f/2.8S
This is beautiful Fons!
Daniel Diggelmann
ARTUROARTISTA
  • I don't like ladybugs.
    • APM Pintor
Re: December 2024
« Reply #245 on: December 30, 2024, 20:21:30 »
Zorki 3-C
Re: December 2024
« Reply #246 on: December 30, 2024, 20:37:36 »
Thanks Paco
Jürgen Pfeiffer
  • You ARE NikonGear'23
Re: December 2024
« Reply #247 on: December 30, 2024, 21:30:58 »
Zf  -  Z 105mm f/2.8S
beautiful, indeed
Jürgen Pfeiffer
Re: December 2024
« Reply #248 on: December 31, 2024, 00:18:31 »
I purchased a Kolari  IR clip-in filter for the Z cameras. Had Kolari also shipped the magnetic fastener plate I ordered, the setup might fit for field testing. As they didn't even though I had paid for the item, the filter rattles inside the camera mount so I won't use it for any serious business until the missing item arrives. If it ever manifests itself. Without the internal filter being held in position, image sharpness certainly will suffer, and this fact showed itself clearly on my test pictures.
Any way, I availed myself of the opportunity to mount a few assorted fisheye lenses to the IR-modified Z cameras. Here the tiny Meike 4mm f/2.8 fish was abused by me on the Z5. The lens is not bad, despite the various flare spots some of which might be caused by the Kolari (?) and considered its very low price, might even be value for the money. Do remember it is designed for DX, however. Thus the image circle on the FX models is on the small size. The Sunex 5.6mm f/5.6 or any of the various Fisheye-Nikkors would be a better option for FX. The Meike is claimed to cover 220 degrees and most frames either had my fingers inside the image circle, or my feet, or both.
Re: December 2024
« Reply #249 on: December 31, 2024, 06:51:02 »
Early morning
D4S 24-70/2,8G
Re: December 2024
« Reply #250 on: December 31, 2024, 10:08:36 »
Considering the setup, your feet show remarkably low distortion here Birna :)
Re: December 2024
« Reply #251 on: December 31, 2024, 10:13:09 »
My Birkenstocks look almost normal :)
Re: December 2024
« Reply #252 on: December 31, 2024, 10:27:11 »
December  30
2 Images merged, the little fellow happened to be in one
town of Oss
Zf  -  nikkor 35mm f/1.4 ai
Re: December 2024
« Reply #253 on: December 31, 2024, 10:48:49 »
beautiful, indeed
Thank you Daniel, thank you Jürgen
Re: December 2024
« Reply #254 on: December 31, 2024, 12:41:19 »
More Fisheye fun -- this time, the AFD 16mm f/2.8, which (before being abused by me ...) is in fact a very good performer in IR.
