Author Topic: [THEME] Panorama, not stitched  (Read 93374 times)
Lars Hansen
  • Zealand, Denmark
Re: [THEME] Panorama, not stitched
« Reply #210 on: April 26, 2025, 19:54:36 »
From the same day and place as the my former pano - just later in beautiful low afternoon sun.
Jürgen Pfeiffer
  • You ARE NikonGear'23
« Reply #211 on: April 26, 2025, 21:56:05 »
Beautiful rural scenery and wonderful light, Lars. The branch on the right in the picture would probably have fallen victim to my stamping tool. :) :)
Jürgen Pfeiffer
« Reply #212 on: April 27, 2025, 14:34:17 »
+1
Cropping out the right side also works - but then it would unfortunately no longer be a panorama.
« Reply #213 on: April 28, 2025, 11:39:37 »
Very nice. I'll be the odd one out re. the branches on the right. I'd leave them, just enough "imperfection" to really put the viewer in the spot.
senecaman
« Reply #214 on: April 28, 2025, 13:11:35 »
Great shot Lars
The more I see panorama and 16:9 format pictures, the less I enjoy the “traditional 3:2 and 10:8 view
Andrew
« Reply #215 on: April 28, 2025, 18:27:18 »
 ;D ;D ;D
« Reply #216 on: April 30, 2025, 13:19:43 »
Great shot Lars
And to add insult to injury ... here's one at 3:1  8) 8) 8). 6x17 on Adox CHSii-100, 210mm, f/16
Lars Hansen
  • Zealand, Denmark
« Reply #217 on: April 30, 2025, 19:01:51 »
+1
Great shot Lars
Jürgen, Hugh, Hans and Andrew - many thanks!
I kept the branch to the right for similar reasons as Hans suggest - it acts as a kind of frame and also part of the surroundings .. and as Hugh says, it would be less pano cropped. I think, like Andrew say, some images really works much better in pano format.
Here is a version with the suggested removal of the branch and a "lesser pano" 16:9 crop with more sky, the tree to the left and a small stream in the bottom.
Lars Hansen
  • Zealand, Denmark
« Reply #218 on: April 30, 2025, 19:36:06 »
And the other side of the hill - 30 min. later.  Don't mention the ropes.. it's "context"  ;D
« Reply #219 on: May 01, 2025, 07:11:50 »
I like this one best.  The house is out of the center, thereby removing the unspoken suggestion that it is important.  The ropes seem to balance with the house, across the frame.
Jürgen Pfeiffer
« Reply #220 on: May 01, 2025, 08:54:13 »
Same with me. The ropes are important and don't bother at all.
Lars, I hope You didn't get me wrong with the stamp remark. However, I didn't mean removing the branch by cropping the picture, because the wide image section is very convincing.
Jürgen Pfeiffer
Lars Hansen
  • Zealand, Denmark
« Reply #221 on: May 01, 2025, 14:06:36 »
Many thanks Keith and Jürgen!
Thanks for your input about the ropes - yes, I included them intentionally when I took the shot. As a kind of frame and context - and left them there. It is also my own favorite - including the bridge and more of the river works better. In general I've taken the shots with the final pano image in mind - whole frame and no horizontal crop in post.
Keith, good point about the balance across. I know what you mean about the centering of the house. It's the church in the small town and to me it has a significance in the image, but that's just a slightly sentimental attachment.
Jürgen - not at all. I only find it interesting and inspiring how people react to my images - to reflect on and learn. I "stamped" it away as suggested for comparison with a minor crop due to a part of the thick branch having thin branches in the background. The second was as a reaction to Andrews comment - a slightly cropped 16:9 that is still a wide ratio for comparison.
Can I ask you both a question? Does the images look a bit dark and lacking tonal contrast to you? In such images, I always process with a natural look in mind.
Reason I ask is that I replaced my old monitor with a factory calibrated sRGB (Dell 27" 4K) and since then I've had some challenges with colors, tonal contrast and brightness in post processing in Capture One - the output sometimes has an odd color shift and appears darker. Probably differences in the ICC profiles used in Capture one and the monitor. I've adjusted monitor brightness and contrast.
Jürgen Pfeiffer
« Reply #222 on: May 01, 2025, 16:56:23 »
Lars, for me the images look good, not too dark no missing contrast. In reply #217, the upper image lloks a bit more contrasty and also a bit warmer in white balance. What ICC profile do you use for output to NikonGear in C1?
Jürgen Pfeiffer
Lars Hansen
  • Zealand, Denmark
« Reply #223 on: May 01, 2025, 17:35:49 »
Many thanks, Jürgen - that's great to know. For JPG export, I've used the sRGB IEC61966-2.1 profile for many years. Things has undoubtedly evolved over the years, so maybe I should look for a more recent profile - a newer standard profile.
I use the built-in "Nikon Z7 Neutral" ICC profile in C1 - same profile as in camera. Also, I use a linear curve - no film curve etc.
In #217 the WB is the same but small difference in tint, differences in curves, shadow recovery and exposure differs so there is a difference.
« Reply #224 on: May 02, 2025, 07:29:34 »
I happen to view Nikongear.net on my better Eizo calibrated monitor today.  The images look "natural", with no perceivable color cast.
