Author Topic: August 2024  (Read 78756 times)
Ian Watson
Re: August 2024
« Reply #75 on: August 07, 2024, 17:21:42 »
I try to reproduce the feel of the moment I took the picture. Emotional fidelity. The original version is quite "there"
Ah. I see it now. You need a photograph to establish the scene first. On its own, as you have discovered, people tend to get the wrong idea.
Re: August 2024
« Reply #76 on: August 07, 2024, 21:09:46 »
Paco thank you very much.
Re: August 2024
« Reply #77 on: August 07, 2024, 21:58:01 »
A new home
D850 58G
Re: August 2024
« Reply #78 on: August 07, 2024, 22:58:46 »
UV sunflowers. Taken with my old workhorse, Nikon D3200 with built-in Baader-U filter and the Coastal 60mm f/4 APO lens. Not high UV levels on a hazy day, yet I was able to get the shot with a hand-held camera.
Re: August 2024
« Reply #79 on: August 08, 2024, 00:44:19 »
People walking on the 'wad', the seafloor at low tide!
Zf  -  Z 105mm f/2.8S
very beautiful scene, nice scale!
Re: August 2024
« Reply #80 on: August 08, 2024, 00:45:27 »
That's the problem we all face: getting the communcation across to any receivers. Humans are not telepathic and our sensors need external stimuli.
sometimes a photo is not the right medium to express
Re: August 2024
« Reply #81 on: August 08, 2024, 00:46:23 »
I tend to the principle of life long learning. Thank you
Re: August 2024
« Reply #82 on: August 08, 2024, 01:08:44 »
Going to be stormy.
aerobat
Re: August 2024
« Reply #83 on: August 08, 2024, 06:46:40 »
A new home
D850 58G
A lovely pair John!
Daniel Diggelmann
Jürgen Pfeiffer
  • You ARE NikonGear'23
Re: August 2024
« Reply #84 on: August 08, 2024, 09:45:10 »
A new home
D850 58G
this is a picture to celebrate global cat day 2024
But thank god, every day is cat day.
Jürgen Pfeiffer
Re: August 2024
« Reply #85 on: August 08, 2024, 10:02:02 »
Same sunflowers as last picture, however this time done in IR with the Laowa 11mm f/4.5. The wide angle in conjunction with IR filtering makes for a dramatic sky.
Interestingly, some flower head features are not IR-bright, which is unusual. The disk florets are IR dark, a parallel to the bracts (phyllaries) of dandelions which also appear IR black. The IR-dark phyllaries are seen on the sunflower heads too.
Re: August 2024
« Reply #86 on: August 08, 2024, 12:47:38 »
Birna, there's something weird in the version I'm viewing
A border between sharp and unsharp.
Almost like processing hadn't finished????
Re: August 2024
« Reply #87 on: August 08, 2024, 15:41:13 »
Going to be stormy.
Wonderfully atmospheric shot
Re: August 2024
« Reply #88 on: August 08, 2024, 15:42:19 »
Horse in the Sunset
Re: August 2024
« Reply #89 on: August 08, 2024, 16:16:55 »
Thank you Frank
