Author Topic: Z bodies with FTZ and AI-S lenses  (Read 18497 times)
Re: Z bodies with FTZ and AI-S lenses
« Reply #15 on: July 10, 2024, 05:02:14 »
I currently have 3-FTZ and 2-FTZII, plus one dumb adapter.  I plan to acquire more FTZs if/when the price of used ones comes down a bit.
« Reply #16 on: July 10, 2024, 05:43:42 »
Only one?  LOL  ;D
It is a beginning...   ::)  ;D
whatdoido
  • You ARE NikonGear'23
« Reply #17 on: July 10, 2024, 12:04:17 »
I was reading on DPreview where some people said unchipped AI-S would not give a "green dot" focus indicator when eye-AF/detect is used.  Is this correct and  quirk of manual focus lens with eye detect only?
And if not using eye-AF/detetc, does the green dot focus confirm work if using a single focus point?
Unfortuantely, there isn't a brick and motar shop nearby where I can test this myself.
Ian Watson
« Reply #18 on: July 10, 2024, 14:40:59 »
First of all, the only Z-system camera to offer eye detection with manual focus is the Zf. It will do this whether or not the lens has a chip.
The green dot is still present but a bit of a relic. The red square showing the focus point/area turns green to confirm focus. However, this behaviour requires a chipped lens. Otherwise you are left to zoom in and confirm focus yourself.
whatdoido
« Reply #19 on: July 10, 2024, 15:41:51 »
@Ian,
That's interesting and exactly the insight that isn't widely available.  I don't think I'd be looking at a ZF (i didnt like the Df) form factor so is the eye autodetect functionality on the Zf a firmware functionality (zf being newer than the z8) or is there something more mechanical?  With the FTZ adaptor needed  it seems less likely a physical constraint - although I recal the Df having ability to hide the indexing tab (??) so it could mount pre-AI lenses too.
« Reply #20 on: July 10, 2024, 16:09:25 »
Yes, that is correct.
On the Df with the aperture follower tab locked in the "UP Position", one can mount non-Ai lenses and still get full exposure facilities.  In this mode of operating the Df, one has to set the taking aperture on BOTH the body (via a control wheel) and on the lens (using the len's aperture ring).
Why on earth can we not do the same facility on the Z cameras with the FTZ adapter???
Just the appropriate firmware is needed!  Come on Nikon - listen up!
I would be prepared to pay for such firmware as a separate item - as is done with some of the Z6II video firmwares.
@Ian,
although I recall the Df having ability to hide the indexing tab (??) so it could mount pre-AI lenses too.
Ian Watson
« Reply #21 on: July 10, 2024, 17:27:23 »
There is no mechanical connection with my AI lenses and a dumb adapter. It is purely in the firmware.
