Author Topic: May 2024  (Read 54254 times)
Ian Watson
Re: May 2024
« Reply #45 on: May 06, 2024, 17:12:02 »
School was valued highly in 1845, when this schoolhouse was built. The community put both time and money into building it. The wood is old-growth white pine; much fancier than was typically used for farmhouses. The windows were expensive and there were six of them!
Nikon Zf, 35mm f/2 AI.
aerobat
Re: May 2024
« Reply #46 on: May 07, 2024, 06:33:22 »
Camera fun on a rainy day - D850 & AF-S 24mm
Daniel Diggelmann
Re: May 2024
« Reply #47 on: May 07, 2024, 10:59:17 »
'Tertitten', my local museum heritage railway is run by true enthusiasts :) Today they were busy shunting carriages using a small diesel loco, a "young and fresh" model from 1965. The railway and other hardware are late 1890's so much older.
IR with the Nikkor 40mm f/2 SEZ on Z5. Heavy overcast and thus little darkering of the sky occurred.
Re: May 2024
« Reply #48 on: May 07, 2024, 11:22:40 »
Where is the spring? Falling snow flakes transformed to quite large water droplets. In spite of the dark snowy and overcast day heavily cropped handheld shots at 700mm and f/9 (500PF+TC-14E III on D500) still gave acceptable results. 8)
Re: May 2024
« Reply #49 on: May 07, 2024, 11:40:22 »
Last one was for yesterday. Here is a followup for today with bigger droplets.
Re: May 2024
« Reply #50 on: May 07, 2024, 12:42:42 »
Bumblebee
Z7_2,  Z 105mm f/2.8S
Ian Watson
Re: May 2024
« Reply #51 on: May 07, 2024, 17:04:20 »
Even Chuck Norris would have needed a tripod. Well done!
Ian Watson
Re: May 2024
« Reply #52 on: May 07, 2024, 17:05:17 »
Pay attention, class.
Re: May 2024
« Reply #53 on: May 07, 2024, 18:19:18 »
Frog
Z8 100-400 f4.5-5.6 @400mm  f8 DX mode
Re: May 2024
« Reply #54 on: May 07, 2024, 18:23:41 »
simple
Re: May 2024
« Reply #55 on: May 07, 2024, 19:37:55 »
The D500 is still one if the best cameras that Nikon ever built. I really love it. Thank you for showing the power
Re: May 2024
« Reply #56 on: May 07, 2024, 20:38:12 »
Thanks, the VR certainly helps, and using the central AF point at narrower apertures and low light levels.
kasperbergholt
Re: May 2024
« Reply #57 on: May 08, 2024, 10:38:07 »
Latest lens addition - Carl Zeiss 35mm f/2 distagon - on top of a Japanese edition of a Bill Evans record (Paris Concert Two).
-- Kasper Bergholt
Luc
    • Flickr
Re: May 2024
« Reply #58 on: May 08, 2024, 13:54:59 »
Sunlit Novotel against overcast sky.
Ricoh GRIII
GRIII_R0000505 by Luc de Schepper, on Flickr
Re: May 2024
« Reply #59 on: May 08, 2024, 17:53:49 »
May 8
flags
Zf  Z 40mm f/2
