Author Topic: May 2024  (Read 75628 times)
Dogman
Re: May 2024
« Reply #165 on: May 21, 2024, 22:03:06 »
This is Katie.  She's one of my retinal specialist's assistants.  She's holding the device she used to measure the pressure in my eyes--it says it's called a "tonometer" on the label.  I dunno, I'm just glad I don't have glaucoma to add to all the other things wrong with my eyes.  It's really a bitch to be a photographer and not be able to see very well.  Photographed with a Fuji X-Pro2 and the Voigtlander 28mm ƒ/2 Ultron lens--the pre-aspherical model.
Re: May 2024
« Reply #166 on: May 21, 2024, 22:43:48 »
As you said, it's a bitch but you nailed them, the focus and the shot as well.
Re: May 2024
« Reply #167 on: May 21, 2024, 23:31:04 »
Nightflowers (Zf, Voigt 1.0/50mm @f/1.0 and 250th of a second with ISO 3200)
I could have handheld 1/15 s to use less of the ISO but I had the camera set at 1/250 s which gives us kind of an interesting study in grain vs noise ;-)
Dogman
Re: May 2024
« Reply #168 on: May 22, 2024, 01:39:49 »
Thank you, Airy.
Re: May 2024
« Reply #169 on: May 22, 2024, 07:48:30 »
Nightflowers
Lovely blue mood...was this actually at night?  Also, your extreme closeup of the broccoli is a reminder tthat it could be rewarding to look closely at everyday objects.
Re: May 2024
« Reply #170 on: May 22, 2024, 07:49:47 »
May 21
RGB tulips
Z7_2  -  Z 105mm f/2.8S
Fons, you are one of our masters of color.
Re: May 2024
« Reply #171 on: May 22, 2024, 08:44:58 »
+1
Re: May 2024
« Reply #172 on: May 22, 2024, 11:44:45 »
Thank you Keith! Nef developed in DxO photolab 7!
Re: May 2024
« Reply #173 on: May 22, 2024, 11:47:15 »
Photographic movement
D850  -  58mm f/1.4g
Re: May 2024
« Reply #174 on: May 22, 2024, 12:14:46 »
D850  -  58mm f/1.4g
This is super!
Re: May 2024
« Reply #175 on: May 22, 2024, 12:18:20 »
Oh, good one, Fons!
Re: May 2024
« Reply #176 on: May 22, 2024, 12:29:07 »
Fons does the experimental moves -- excellent!!
Re: May 2024
« Reply #177 on: May 22, 2024, 12:29:56 »
Industrial design by IR
Re: May 2024
« Reply #178 on: May 22, 2024, 13:32:37 »
Akira, Bruno, Birna thank you!
Re: May 2024
« Reply #179 on: May 22, 2024, 13:34:08 »
D850  -  58mm f/1.4g
Beautiful Fons
