Author Topic: Nikon FE - treat of the (birth)day  (Read 7556 times)
Ian Watson
Re: Nikon FE - treat of the (birth)day
« Reply #15 on: April 12, 2024, 15:25:30 »
Happy birthday, Airy!
« Reply #16 on: April 12, 2024, 23:55:05 »
Thanks !
« Reply #17 on: April 12, 2024, 23:58:09 »
What a fabulous find, and a trip down memory lane for me.
I bought an FE back in 1980 to accompany an FM - my first Nikon (purchased in 1979). Both cameras were indestructible and served me well for more than 15 years. I sold the FE in 1995 to get an F4s but could not bear to part with the FM. Only last week I was researching B&W developing chemicals with a view to running a film through it again.
Nice one too, and with one of my favorite Nikkors. Why did you prefer the FM over the FE ?
« Reply #18 on: April 13, 2024, 01:50:04 »
When comparing the FE2 to the FE there are many advantages for the FE2. However an advantage for the FE is it has a noticeably softer shutter and mirror sound and I would think less vibrations noticeable at slow shutter speeds.
aerobat
« Reply #19 on: April 13, 2024, 08:01:29 »
Happy birthday Airy - this FE looks the part with the crocodile leatherette. If I remeber correctly the FE was liked for its capability to do long exposures. The FE was my first camera which I bought used as a student. It got replaced by a new FM2 with the first salary as I wanted to force myself to work manually.
Daniel Diggelmann
senecaman
« Reply #20 on: April 13, 2024, 10:24:33 »
It was because the FM was 100% mechanical and I could estimate exposures using the old “sunny 16” method. If I remember correctly the FE only had a 1/90 shutter speed without batteries. The F4 which replaced it was totally dependent on battery power so a  functional back up was always useful.
Andrew
Bill De Jager
« Reply #21 on: April 14, 2024, 00:22:29 »
Happy belated birthday, Airy!
My first new camera, and the first one I bought, was a Nikon FE in December 1982.  That camera was my only camera for over 20 years and served me very well during that time. When I finally sold it the shutter was showing a lot of wear but still worked as well as always.
« Reply #22 on: April 14, 2024, 13:27:57 »
Thank all. I just completed my first roll of HP5+. We'll see next week if all went well. My main concern is with the metering, after the bad experience from two years ago. With this one, the metering seems consistent, but I have to check for offsets.
I am quite used to spot exposure (even multispot on the Canon T90), or matrix metering as a near-foolproof alternative. Here, that's a different story...
« Reply #23 on: April 14, 2024, 13:51:12 »
Another "adaptation point" is ISO sensitivities. I chose a 400 ISO film to cope with relatively low light (I mostly shoot handheld). Given my taste for wide apertures, I had to buy a variable density filter to adjust for bright daylight. Indeed, 1/1000s shutter speed is a limit long forgotten.
Next, another test roll with a very different film - Ilford XP2.
Eddie Draaisma
« Reply #24 on: April 23, 2024, 16:43:53 »
A black FE, my first Nikon that I bought in 1979 together with a Nikkor 35mm F/2 Ai lens. Total cost just below 700 Euros then...
