Author Topic: April 2024  (Read 62121 times)
Re: April 2024
« Reply #120 on: April 11, 2024, 22:48:54 »
I love it Paco. The grain with the D1x is even better
Re: April 2024
« Reply #121 on: April 11, 2024, 23:41:57 »
Thank you. Please, do show if you feel like it. I don't have one
Re: April 2024
« Reply #122 on: April 12, 2024, 00:03:32 »
Waiting for a second 'new' battery pack for the D1X. apparently the Li-Ion kind is charged OK by my available original chargers for the D1/D1X/D1H class cameras. However, the old Ni-MhH batteries are mostly dead by now and will work only in my IR-modified D1 which apparently requires less electric juice to operate (?).
Re: April 2024
« Reply #123 on: April 12, 2024, 00:11:47 »
At present I'm working intensively to get ready a series of lectures on Aquatic botany to be held during the sprimg. Perhaps I'm nit-picking too much about the quality of my illustrations, as the completion date for the sequences move closer and closer to my abosulte dead-line next week. Oh well. They'll be ready on time.
I had a short break this afternoon and an epiphany when I looked to the window sill noticing the last remnants of daffodils I put there some days ago. Ruth is currently in Australia for three more weeks and she know that I  -- as the botanist of the family  -- easily will kill any plant left in my care. Thus she has set up a contingency plan involving friends to secure the survival of her potted plants while she is down under. The daffodils weren't included so they are sure to die off prematurely. However, not without leaving a permanent imprint on my Z5 IR camera. Now, posting this and returning to work.
Re: April 2024
« Reply #124 on: April 12, 2024, 08:02:59 »
The D1x needs more electric.  I have a few Ni-MhH but they are not perfect. The two new Li-Ion work perfectly, but it's a nuisance the D1x will stop working without warning when the batteries are 'empty'
aerobat
Re: April 2024
« Reply #125 on: April 12, 2024, 09:19:21 »
love the interpretetion of these daffodils Birna
Daniel Diggelmann
Re: April 2024
« Reply #126 on: April 12, 2024, 13:06:15 »
April 12
cabbage field
D3S  105mm f/1.4
aerobat
Re: April 2024
« Reply #127 on: April 13, 2024, 08:22:29 »
Teguise - D850 & AF-S 20mm f/1.8
Daniel Diggelmann
Re: April 2024
« Reply #128 on: April 13, 2024, 08:52:52 »
April 24
the gathering
Zf - Z 40mm f/2
Darkslide
  • Be patient - I'm new!
    • Ian Grandjean Photography
Re: April 2024
« Reply #129 on: April 13, 2024, 09:49:07 »
Uninvited (despite the grains!) but very welcome guest for breakfast this morning...
24-200 f/4-6.3
Ian Grandjean
Cameras, lenses, stuff...
Re: April 2024
« Reply #130 on: April 13, 2024, 17:15:35 »
At dusk.
Re: April 2024
« Reply #131 on: April 13, 2024, 18:28:02 »
My small IR kit, using a lens focal length factor of approx. 2X. I have given priorities whenever possible to smaller and lighter lenses, however as focal lengths grow that becomes rather difficult.
From left to right, middle row: Laowa 11mm f/4.5 (using rear-mounted gel filter), Viltrox 20mm f/2.8, Nikkor Z 40mm f/2 SE, Nikkor 85mm f/2 AI, Voigtländer APO-Lanthar 180mm f/4. All lenses except the Laowa are CPU-enabled. The niceness of this kit is that most can take 52mm filters (20-180mm optics).
Rear row: Nikkor Z 400mm f/4.5, very lightweight for its focal length, however cannot use internal filter so requires expensive 95mm filter size.
Front row: GPS recorder Transystem GL-770M, Nikon Z5 (full-spectrum modified) with extra power pack and Foolography 18'N2 GPS module, FTZ adapter for the F-mount lenses.
All lenses are good to excellent in IR, however the 400mm should not be stopped down all the way unless you specifically wish to have an IR hot spot :) I tend to use it in the f/4.5-f/5.6 range where it performs excellently for IR. The old Nikkor 400mm f/3.5 ED-IF can use internal filters (39mm) and is maybe a tad better for IR, but is much heavier and of course manual focus only. The Zoom-Nikkor 80-200mm f/4 AiS can substitute for the 85 & 180 lenses for some assignments. If I plan on shooting close-ups, I might bring either the Micro-Nikkor 105mm f/4 or UV-Nikkor 105mm f/4.5 instead of the 85mm. If I have any urge to lift weights, the wonderful AFS 200mm f/2 Nikkor can replace the CV 180.
aerobat
Re: April 2024
« Reply #132 on: April 13, 2024, 21:39:59 »
technically bad - didn't watch the settings and ended up with ISO 6'400 on D850 - thanks to all the crutches in Adobe Lr and Ps it's half decent. Lens used is AF-S 300mm PF.
Daniel Diggelmann
Darkslide
Re: April 2024
« Reply #133 on: April 14, 2024, 08:16:34 »
Sun setting over a field of wild orchids, Gers, South West France
Ian Grandjean
Re: April 2024
« Reply #134 on: April 14, 2024, 11:57:47 »
April 14
Wisteria the earliest in bloom ever remembered
D850  28mm f/1.4
