Author Topic: Thoughts on Micro Nikkor 105mm f2.8  (Read 9157 times)
Zang
Re: Thoughts on Micro Nikkor 105mm f2.8
« Reply #15 on: December 25, 2022, 05:07:58 »
A question to anyone who has Micro Nikkor 105mm f2.8 AI-S. If you can help measure precisely the height of front element part that raises above the middle helicoid then I can easily figure out the spacing issue. Can anyone please help? :)
« Reply #16 on: December 25, 2022, 12:51:07 »
Kenneth worked with the lens some years ago and made a couple of videos (Part1, Part2):
https://www.youtube.com/watch?v=lNA7G2JdDqU
https://www.youtube.com/watch?v=sgBfkfmYo7U&t=3s
But those are time laps videos and not the usual where all details/measurements are shown.
So probably not of much help. It is probably part2 if any help. I have not watched them in details.
« Reply #17 on: December 25, 2022, 14:58:10 »
The gap measures 2.50mm on my sample of the 105AIS.
Zang
« Reply #18 on: December 25, 2022, 16:13:52 »
Thanks Meper. I did not find any details in the video that tell me either the thinner spacer should go to the front or back.
« Reply #19 on: December 25, 2022, 16:23:18 »
No spacer image either on Richards page (as far as I could see):
https://richardhaw.com/2017/02/19/repair-micro-nikkor-105mm-f2-8-ai-s/
I wonder if those spacers thickness could be individual pr. lens?
Zang
« Reply #20 on: December 25, 2022, 17:02:19 »
Thank you so much Birna! I trust you did the same but I used the tip of the caliper for measurement and mine was 2.82mm. That means most likely I put the rings in wrong order. The thinner should go to the rear side and the thicker one should go to the front side. They measure 0.5 and 0.05 each so the difference seems to match.
Zang
« Reply #21 on: December 25, 2022, 17:06:19 »
That would be the worst for me. With mass production lens, I can't believe they did that. There is a different way to calibrate the CRC based on my assessment of the design.
Zang
« Reply #22 on: December 25, 2022, 19:49:43 »
After swapping the rings, the measurement is 2.52mm, exactly as Birna's lens has. I did nonscientific testing at MFD and f2.8 and f5.6 and to my naked eyes, the lens performs identically before and after the rings swap.
Zang
« Reply #23 on: December 31, 2022, 06:03:14 »
...I was just wondering, how that was possible. There was 0.3mm difference in the CRC relative position after I swapped the rings. How come, the test pictures were still razor sharp when I put the rings wrong? I did test the lens quickly after the swap and it was still razor sharp. Of course, I only tested the lens near MFD. I will post a couple of test photos from the same lens with the new configuration this weekend.
Gerhard2006
« Reply #24 on: January 18, 2023, 06:58:25 »
The bottom line is you got it back together again and it’s razor sharp and I have this lens and totally agree with you. It has become my favourite lens and it’s in my camera bag at all times. I even chipped it and it works great on my Z5 with my FTZ adapter. Regards Gerry
Zang
« Reply #25 on: January 22, 2023, 17:11:51 »
Thanks! The best part is, my son paid $20 for it plus D70. I got both free from him anyway. The lens looks pristine and the image quality is incredible.
« Reply #26 on: February 07, 2023, 13:32:10 »
These shims usually go together to give a specific distance as a set.
The technician assembling and adjusting the lens when it is build can choose from a variety shims that together give the closest thickness to what is needed.
By having several shims you can have more options with less amount of shims.
Same technique as under the F-Mount.
Zang
« Reply #27 on: February 07, 2023, 14:19:22 »
That makes sense. I asked people in several forums and it seems like the measurements were pretty close to what Birna provided. I decided to swap the rings to get close to that configuration.
Interestingly, I tested the lens before and after the swap and the image quality was nearly identical.
