Author Topic: [Theme] Trees  (Read 104847 times)
Re: [Theme] Trees
« Reply #165 on: January 05, 2023, 21:14:43 »
Mediterranean pano.
  Z6, 85mm 1.8s
Matthew Currie
Re: [Theme] Trees
« Reply #166 on: January 06, 2023, 03:51:05 »
I don't think this one has come up here before.  Going through some old slide scans I bumped into this one, which always reminds me a little of the Marvell lines "My vegetable love should grow/ Vaster than empires, and more slow."
Re: [Theme] Trees
« Reply #167 on: January 06, 2023, 15:15:40 »
Broody Matthew
Here's some more multi-trunked ones
Re: [Theme] Trees
« Reply #168 on: January 06, 2023, 15:39:01 »
Do any of you have much Mistletoe growing near you?
I've discovered that Herefordshire is well known for Mistletoe cultivation (there used to be Mistletoe fairs each winter).
Here are some examples (likely to be naturally occuring), with noticeably different colour leaves
In the last case, many of the leaves have been lost, leaving mainly the berries
(it's usually the other way round when birds have been involved, so if any of you know the reason, please share).
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #169 on: January 06, 2023, 15:51:02 »
Mediterranean pano.
  Z6, 85mm 1.8s
Very Mediterranean mood and nice "rhythm" in the trees Paco - can almost hear the cicadas :)
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #170 on: January 06, 2023, 15:54:38 »
Nice sub theme :-)
Barely multi-trunked.
Ian Watson
Re: [Theme] Trees
« Reply #171 on: January 06, 2023, 16:40:18 »
Here is an example of the damage a beaver can do to even a mature tree. The gnawing at the base goes all the way around, killing the tree. Park staff cut off the rest of the tree so it would not hurt somebody when it falls. The other mature trees in the park have been protected with chicken wire.
Nikon Z6, 35mm f/1.8S.
Re: [Theme] Trees
« Reply #172 on: January 06, 2023, 18:01:44 »
reflection
D850, 28mm f/1.4
Re: [Theme] Trees
« Reply #173 on: January 06, 2023, 19:03:24 »
Lovely and sensual.
Re: [Theme] Trees
« Reply #174 on: January 06, 2023, 19:04:16 »
reflection
D850, 28mm f/1.4
Sulernuse of the gear. Detailed magic
Lars Hansen
  • Zealand, Denmark
Re: [Theme] Trees
« Reply #175 on: January 06, 2023, 19:40:23 »
reflection
D850, 28mm f/1.4
Fons - very nice! - is it two images/double exposure or is the water covered with leaves?
Re: [Theme] Trees
« Reply #176 on: January 06, 2023, 20:31:48 »
Thank you Paco, thank you Lars,
I turned the image a 180 degrees around.
Re: [Theme] Trees
« Reply #177 on: January 06, 2023, 21:18:03 »
Highly effective.
Re: [Theme] Trees
« Reply #178 on: January 06, 2023, 22:37:07 »
Those trees have really suffered from the work of the beavers Ian.
Whereabouts are you based?
reflection
I love the results here Fons
Re: [Theme] Trees
« Reply #179 on: January 06, 2023, 22:49:13 »
Thank you Anthony and Colin!
