Author Topic: June 2022  (Read 52961 times)
Re: June 2022
« Reply #15 on: June 02, 2022, 14:13:21 »
Paco, Paco, Paco. Summer indeed!
Re: June 2022
« Reply #16 on: June 02, 2022, 14:23:48 »
I'm very happy to see you here. Always missing your work  :)
Re: June 2022
« Reply #17 on: June 02, 2022, 19:19:24 »
Thanks, Paco <3
Re: June 2022
« Reply #18 on: June 03, 2022, 03:14:05 »
Nice work Akira.  I like the framing of this image and way that you have captured the foreground elements in shadow with the clouds in the evening light.
Mr Cloud, how did you get the clouds to follow the contours of the cityscape.
Akira, I also think the included foreground in your last image is a very good call.
Thank you, Hugh, Jakov and Paco!  The cityscape was necessary to make the size of this beautiful but ominous cloud more pronounced.
Jakov, I have developed a kind of telekinesis over the years.   8)
Re: June 2022
« Reply #19 on: June 03, 2022, 03:15:08 »
A midday thunder.
Re: June 2022
« Reply #20 on: June 03, 2022, 10:16:43 »
A midday thunder.
Youza!
That's a great catch, wow!
Re: June 2022
« Reply #21 on: June 03, 2022, 11:21:35 »
Akira, Akira, Akira
i see you are shaping thunder to the landscape now...
Re: June 2022
« Reply #22 on: June 03, 2022, 12:33:46 »
Youza!
Akira, Akira, Akira
Thank you, Hans and Jakov!
Capturing the lightning is pure matter of luck out of many failed attempts.  This was a lucky result of just the second or third attempt.  Right after I had captured this lighting in the left 1/3 of the frame, the direction of the strong wind changed to blow straight to me and it rained harder.  So, I had to grab the camera on the tripod and rush into my place.
Re: June 2022
« Reply #23 on: June 03, 2022, 15:17:40 »
Now, that´s timing!
  Strong image Akira
Re: June 2022
« Reply #24 on: June 03, 2022, 15:19:34 »
Shadow shelter.
  D5300 ir, 58mm 1.4g
Re: June 2022
« Reply #25 on: June 03, 2022, 17:42:32 »
aerobat
Re: June 2022
« Reply #26 on: June 03, 2022, 21:14:00 »
Birding with the X100V in St. Andrews
Daniel Diggelmann
Re: June 2022
« Reply #27 on: June 03, 2022, 21:49:19 »
Nice ;)
Re: June 2022
« Reply #28 on: June 03, 2022, 22:26:08 »
Now, that´s timing!
Strong image Akira
Thank you, Paco.  Actually, this is a 13-second exposure.   8)
Wow :o
Yeah!
Re: June 2022
« Reply #29 on: June 03, 2022, 22:50:34 »
Great thunder image, Akira !
