Author Topic: Z9 Release Thread  (Read 170780 times)
Re: Z9 Release Thread
« Reply #345 on: February 14, 2022, 06:58:32 »
Several of my FTZ adapters are dedicated to close-up and macro work and thus are (semi-)permanently joined to their respective specialist lens. These adapters are equipped with the Markins L-bracket for FTZ which serves its purpose very well, but upsets normal handling such as hand-holding the gear. Neither can the L-brackets accept the Z9, or vice versa. That is the issue the FTZ-II neatly solves, and as I don't intend to let it usurp the role played by my Z7 units for close-up work all is working to satisfaction :).
Depending on how the Z9 integrates in my future work schedules, I might get a few more of the FTZ-II.
« Reply #346 on: February 16, 2022, 23:59:33 »
Tower Semiconductors, apparent manufacturer of the sensor for Z9, is acquired by Intel.
https://www.dpreview.com/news/2507277684/intel-acquires-tower-semiconductor-for-5-4b-further-expanding-intel-s-ambitious-foundry-business
Will Z9 carry those "Intel Inside" sticker?!   ;)
« Reply #347 on: March 03, 2022, 08:05:10 »
The current situation with the Raw Files in Adobe Photoshop
 Nikon High Efficiency raw compression modes are currently not supported on:
    Windows ARM64
    ARMv7 and x86 for Android
https://helpx.adobe.com/camera-raw/kb/camera-raw-plug-supported-cameras.html#nikon_note
An advantage at the moment is that the lens profiles are not automatic selected and 'built-in'.  (Via the FTZ adapter)  It's free to choose the lens profile, or not.
« Reply #348 on: March 03, 2022, 08:39:37 »
So, you have got your Z9 then?
« Reply #349 on: March 03, 2022, 10:18:26 »
Did you?  8)
« Reply #350 on: March 03, 2022, 11:49:30 »
Yesss. The Z9 arrived yesterday  :D
« Reply #351 on: March 03, 2022, 11:58:37 »
Congratulations on the new machine are in order. Just share your insights to the benefit of the NG members.
It's an impressive and concentrated piece of technology and digital advances, for certain. It "just works", which is what professional gear is all about. Will I eventually love it ?  early days yet and the jury is out. The Z9 has combined everything I could wish for, and more, in a camera. Likely it will grow on you and deepen your relationship with it over time.
In some ways the Z9 reminds me of my first time with the Nikon F, back in the dark ages of ancient film. An unforgiving equipment that brutally exposes your inabilities to harness and exploit all its tremendous potential. Over time I dearly loved my F and later F2 cameras, in particular the near indestructible F2 Titan . Never came to grips with the F3, though. F4 was OK and versatile, the F5 served its purpose awaiting the dawn of the digital era.
« Reply #352 on: March 03, 2022, 13:44:40 »
Congratulations!
  Following with interest all your findings
« Reply #353 on: March 03, 2022, 14:34:43 »
Thanks Paco and Birna.
I agree, it works, and the Z9 feels special to work with, with all those nearly unlimited possibilities.
The original batteries with the Nikon D4S work also in the Nikon Z9, but you can't use the supplied charger which will only work with the Z9 Battery EN-EL18d and the c version.
A third party battery which works just fine on the D4s will not work on the Z9  giving the following message: "The battery is unable to provide data to the camera and cannot be used. For safety choose a battery designated to use in the camera."
chambeshi
« Reply #354 on: March 03, 2022, 15:02:45 »
I picked up my Z9 late Tuesday - finally! ;D In key respects, there are major differences compared to the D5, in others it perpetuates much in the jizz, ergonomics of a Nikon pro ILC, the menus particularly. I have toned down the fps to 15fps for CH, 10 for CL (likely to tamp down to 7fps), reserving 20fps for Recall Shooting Functions setup. RSF is assigned to Fn3, which is easy to access shooting the camera in horizontal or portrait formats. Single-Point+AFOn to Fn2; WArea-Small+AFOn to Fn1, WArea-Large+AFOn to Sub-selector button, and AFOn so far is on 3D Mode for BBAF.
Despite the chagrin about 'failures' of subject-detect/tracking of the Z9 reported in many forum posts, no flagship MILC is a point&shoot (!), and nothing much changes. It pays to be primed to toggle/swop - and fast - between AF modes on a challenging target....e.g. bird or mammal moving within clutter. MF with Peaking works superbly when needed, even on a fast telephoto.
After reading all the debates about the RAW formats I've gone ahead and set image quality to High Efficiency*. I've no plans to use 15 nor 20 fps in machinegun mode, but have ordered a pair of Delkin cards from BandH, but this will take a few weeks across the pond. I did check the 64gb Lexar CFEXpr Pro after a few shorts bursts, and it was distinctly warm. Anything more sustained may cause overheating....
I've tested my Z9 so far only with the 500 PF, including with TC2 III, with which the focus is still very fast, and 3D easily locked on to a flying Yellow-billed kite, and at some distance. Don't plan to use this combo much, but compared to D850 and D5, the AF is impressive at f11 in responsiveness, and across much of the frame.
Contrary to what I've read in blogs and forum posts, it has turned out to be quite quick to change Shooting Banks, Metering, and Silent-shooting via the EVF with the Z9. The loss of the Metering button from camera top-left is not as serious as I'd feared. In fact it's looking better already to have fps there in its place. Changing AF settings is also much faster - Assign Red-Record to scroll the Front-Rear dials. Overall, Nikon engineers are to be commended for facilitating a Custom setup to control almost all the key controls with the right hand and not leaving the EVF. This now includes Playback, which is one big challenge to muscle memory after so many years on DSLRs - i.e. when chimping to keep trying to press top left of the camera!
All this is an experimental setup...so early days, but the setup file is archived as backup to this computer incase of a vital roll back to 'Last Known Good'. Finally, the other snippet of advice I applied  is to do a full Reset all Settings' of the camera before setting it up. Some fairly experienced Nikonians believe this clears the memory. Nothing to lose with a new camera, or setup file has been backed up as restore is very quick off a card.
« Reply #355 on: March 03, 2022, 15:18:01 »
CFexpress cards do tend to run hot when they're used. They have internal thermal management so they are not expected to malfunction due to overheating (the card slows down when it exceeds a certain temperature, to manage the situation).
« Reply #356 on: March 03, 2022, 16:30:48 »
My friend Alex has one from his job at Ford Motor Company. It feels great but I sure do not need it currently, because my job is now politics and Text work primarily. Wonderful camera,  feels like the first real mirrorless pro body
Nasos Kosmas
  • Athens, Greece
« Reply #357 on: March 03, 2022, 18:28:32 »
Congrats on your new camera :)
« Reply #358 on: March 03, 2022, 20:02:22 »
I don't have my Z9 yet, but it should not be too long now.
What brands of cards do you recommend as SAFE and durable? What size as your folks getting? Are any less expensive? Two slots, so any help on what you are doing appreciated. Any special prices anywhere in U.S.?
I plan to do video as well, so I am looking for a larger card, one supported by the Nikon Z9, and as inexpensive as possible,  but solid.
MILLIREHM
  • Vienna, Austria
« Reply #359 on: March 03, 2022, 23:24:36 »
I was buying some Sony TOUGH 512 MB cards (expensive) and then switched to Angelbirds AV PRO SX 128 MB with 1600MB/s writing speed (warning the 512 MB version is slower).
I sought for maximum speed for serial shootings but am not experienced with lengthy video sessions and their requirements.
Guess you will find cheaper cards but is depending on your needs whether they are sufficient.
Cant say anything yet about safe an durable (had just one card failure in total throughout all the years of digital photography and that was a San Disk Compact flash card in the D800E)
Thats why I am using two cards and mirroring
Wolfgang Rehm
