Author Topic: Saving AdobeRGB+sRGB  (Read 5615 times)
Björn Carlén
  • Errare humanum est
    • flickr
Re: Saving AdobeRGB+sRGB
« Reply #15 on: August 05, 2015, 22:58:17 »
+1 to that, Jan Anne!
Björn Carlén
Huddinge, Sweden
« Reply #16 on: August 05, 2015, 23:11:50 »
The RAW file itself has no understanding of a colour space. It is truly agnostic in this respect. Any colour setting for a RAW *in camera* is purely informative not decisive.
However, once we move the captured data into anything treating the data as an image, the manner in which the data should be interpreted in terms of colour becomes important. The camera is capable of recording colour information outside of any existing colour space. In the processing stages, depending on what use the photo is intended for, we might want to avoid clipping and losses of extreme colour(s) while *editing*. Some loss is inevitable though and more later when the image is printed or exhibited. If we keep the wide gamut space as long as possible, transforming into other spaces more suitable for printing etc. can occur under full user control and utilising the best possible mapping into the final oiutput.
« Reply #17 on: August 08, 2015, 08:38:32 »
I'm adding a reminder that you must set a working color profile for the editing portion of your workflow in Lightroom (or other app).
In most raw converters (like Lightroom), you can not set it at all. The working space is typically a ProPhoto variant. Typically only image editors allow the explicit setting of the working space.
The only reason to set your camera to Adobe RGB when shooting raw is to have a slightly more accurate histogram in camera.
Shoot exactly (Tripod!!) the same scene (something colorful) with Abobe RGB and sRGB and compare the in cam histograms. The look at the histogram in your converter.
Bjørn's post (#16) above summarizes nicely why you want to stay wide.
« Reply #18 on: August 08, 2015, 08:49:54 »
Thank you Andreas. Did not think about this aspect
Andrea B.
  • Technical Adviser
« Reply #19 on: August 09, 2015, 16:56:45 »
View NX2, Capture NX2, Photo Ninja, Affinity all have a preference for setting a colour space. I suppose they can be considered a combination converter/editor?
