Author Topic: *real light edits* modern dance (available darkness with X100T)  (Read 5002 times)
I like the flickr version better, so refer to post TWO
Re: modern dance (available darkness with X100T)
« Reply #1 on: June 14, 2015, 16:33:15 »
I did a sophisticated edit on all of these images, then I saw that FastStone cannot display the TIFFs properly but turns them into something special
depending on what I do editing in Photo Ninja, the results fall into different stylistic categories, after a short while it should be perfectly controllable:
« Reply #2 on: June 14, 2015, 19:02:44 »
Interesting session Frank , when i had the chance to photograph  dancers I always liked it very much , often light conditions are challenging, but the results are worth the trouble
 the extreme edit certainly make them look interesting, will you share any normal light versions ?
« Reply #3 on: June 14, 2015, 20:44:53 »
Yes. Normal versions I will post later. I have to make more decisions, like stark cropping
Re: *real light edits* modern dance (available darkness with X100T)
« Reply #4 on: June 17, 2015, 05:39:00 »
here are some real light edits too:
« Reply #5 on: June 17, 2015, 21:32:23 »
Thanks for posting this edits , very enjoyable
Did you have support for the longish exposures ?
« Reply #6 on: June 18, 2015, 00:06:20 »
No, Armando, I feel the X100T is grown into my hands like the Nikon D3 is or the Nikon F4 was. I can hold her quite steady quite often. When I came to the venue I never even knew if I would be allowed to take any photos, nor did I know if the light levels were halfways in the range I could conquer with the X100 at all. But: The little beauty behaved pretty well, the 100% shots still contain an astonishing amount of detail for the cranked up ISO. RAW Files that is. The HiISO JPEGs are not so well usable, seem overprocessed.
« Reply #7 on: June 18, 2015, 06:49:04 »
Very interesting processing. I like your vision.
« Reply #8 on: June 18, 2015, 08:22:46 »
f=2
ISO=1600
t=1/100 s
« Reply #9 on: June 18, 2015, 08:23:51 »
f=2
ISO=3200
t=1/15 s
« Reply #10 on: June 18, 2015, 08:35:00 »
f=8
ISO=2500
t=1/8 s
faris
« Reply #11 on: July 01, 2015, 13:32:20 »
Frank, a very interesting interpretation.
« Reply #12 on: October 08, 2015, 17:10:47 »
This Dance Production by Karel Vaňek and Guido Preuss is called:
Machine of Desire, 2015
