Author Topic: New monitor  (Read 5137 times)
ianwatson
New monitor
« on: June 19, 2019, 08:14:42 »
Hello everyone,
My 23" Apple Cinema Display is showing its age. The time has come for a new monitor. A bit of research suggests the Eizo CS2420 as an excellent replacement. The size and resolution are similar at 24" and 1920 x 1200. Or perhaps I could indulge in the CS2730 at 27" and 2560 x 1440. (This is the most resolution that I believe my late 2012 Mac mini can handle.) Then there is the wild thought of a shiny new 27" iMac with a 5K display. Shiny might be the operative word with its glossy display.
What do you think? Is 5K a help or a hinderance for editing photographs?
Re: New monitor
« Reply #1 on: June 19, 2019, 10:25:40 »
I am using a 27” iMac from 2015, it has the 5k display. Although shiny it is very good to edit pictures on.
The Retina display makes a huge difference. 5120x2880 pixels makes a difference, so files from a D700 is show nearly in 100% ;)
Re: New monitor
« Reply #2 on: June 19, 2019, 18:18:02 »
Same here (but December 2014).  It is a lovely monitor, but I have not used the Eizo so cannot compare.
ianwatson
Re: New monitor
« Reply #3 on: June 20, 2019, 15:19:38 »
Thank you, Bent and Anthony. The iMac it is  8)
Re: New monitor
« Reply #4 on: June 20, 2019, 16:01:19 »
I recommend the SSD version.  I have applications on the SSD and my data on an external Thunderbolt drive.  It may be that the iMac now uses USB-C.
Re: New monitor
« Reply #5 on: June 20, 2019, 16:04:48 »
Mine is with fusion drive.
All my image files are located on a NAS.
ianwatson
Re: New monitor
« Reply #6 on: June 20, 2019, 20:08:07 »
My current Mac Mini has an SSD and an external 2-disk RAID that is compatible with USB-C. It will be nice to get the full speed from the latter.
