Hello all,
I used to use C/Y Zeiss lenses a while ago and I found they were mechanically perfect. The focus rings were smooth and had exactly same turning resistance. That experience became my reference when it comes to manual lenses.
Recently, I started buying Nikon manual lenses and ended up with 5 items, 55mm f2.8, 35mm f2.8, 28mm f3.5, 80-200 f4.5 and 24mm f2.8 AI. They all have different focusing experience
55mm is looser than Zeiss, but it is totally fine. 35mm is looser than 55mm. Zoom is very loose. I can hear its barrel banging by shaking the lens. 28mm has inconsistent resistance. It changes between being tighter and looser through out the full turn (the pattern is consistent, though). 24mm is surprisingly stiff
24mm is much stiffer than what I consider to be normal but remains pretty smooth end to end. At some point I was thinking about taking it apart for re-greasing. The question goes to those who have gone through that hassle (of fun) if it is worth it to open the lens up? What would be the decision point for doing so or in another word, what level of stiffness is considered to be an issue? I know this is very much down to personal experience but I want to hear your opinions and stories
Zang
