Author Topic: Auto AF fine tune on D850 problem" AF fine tune not available"  (Read 1710 times)
Pistnbroke
Well it worked fine originally on a 24-85 but a few weeks later " AF fine tune not available at this autofocus setting"..all lenses produced this .
U tube videos just said check your settings.  In  the end I did a two button reset and it worked perfect .Changed nothing from my normal settings not even turning off the VR. Half press on the release in LV then  movie/AF  and OK when instructed.
Hope this helps if /when it happens to you.
Re: Auto AF fine tune on D850 problem" AF fine tune not available"
« Reply #1 on: January 24, 2019, 14:39:57 »
You need to have both the live view focus on single center point and the viewfinder AF on single center point.
Pistnbroke
« Reply #2 on: January 24, 2019, 16:59:57 »
Yes had both on single point when it did not work but thanks for the comment.
Gary Irwin
  • A wildlife in habitat shooter
« Reply #3 on: January 25, 2019, 14:55:14 »
EDIT: What I meant to say is when you get the above noted error message when fine tuning and the settings otherwise look OK, exit LV, move the AF point away from centre using the multi-funcition pad, then back to centre by pressing the multi-function centre button, then return to LV. This resets the AF mechanism.
Pistnbroke
« Reply #4 on: January 30, 2019, 17:36:56 »
Gotya Garry ..we now have two methods...thanks
« Reply #5 on: January 30, 2019, 19:00:36 »
When it's too dark, or the subject is not right in front of the camera, it will give the same 'error' message.
