Author Topic: Instagram -- processing and posting tips?  (Read 5110 times)
RobOK
    • My gallery
« on: January 16, 2019, 18:56:16 »
I am going to use Instagram more this year as a way of communicating my images and words. Is anyone here a frequent IG user and can offer tips on workflow and best practices. I have two flows in mind:
1. DSLR (Df or D750) to LR (laptop), process, sync to LR CC (cloud), post from LrMobile on my phone to IG and apply hashtags
2. Use camera app or LrMobile to take images on my phone, process in LrMobile, and post
Open to ideas of other apps or workflows or any other tips on IG.
Thanks,
Rob (@RobOK on IG)
Nikfuson
Re: Instagram -- processing and posting tips?
« Reply #1 on: January 16, 2019, 19:01:43 »
I've started using IG more and apart from various processing methods, the main thing to remember is the square format.
« Reply #2 on: January 16, 2019, 20:49:19 »
I started using it a few months ago and have only a limited experience with it. I'm using the Windows10 app, which can not post, by clicking share on an image, outside of the app, and choosing Instagram as the sharing app. In this way it works and honestly, although it is one of the worst user interface, and app, I've seen, I find it still better than using the phone.
Format does not need to be square. Landscape is free form, portrait is max 4 by 5. As usual with compression on apps and forum, pictures with too much fine details are rendered worse and it is better to reduce size before posting.  It looks like the max dimension is 1080, which I'm using, but I have not crosschecked the info.
Hashtags are the most important vehicle to viewers. I've noticed that it is better to chose moderately large one, in the 100.000 posts for example, instead of very generic one with posts in millions or more where the flux is too fast for the picture to stay on top long enough.
Followers do fluctuate a lot. I often get 10 more on 1 picture only to be back -7 the next day. Some followers are also only there to sell stuff or spam or get you to follow in return. From more experienced friends, getting to followers in the thousands requires a constant stream, posting every day or even several times a day.
Watch out, there is a max number of hashtags. If you type in more, you get the post but not the caption. Error message are very basic: it only says that something went wrong. The solution is simply to reduce the hashtags and it eventually works.
@brunoschroder
RobOK
    • My gallery
« Reply #3 on: January 16, 2019, 22:22:36 »
Good info, thanks!
I think the max hashtags is 30, I also heard that if you use 30 every time and use the same 30 every time you will drop in rankings. Agree on using mid-volume hashtags. Glad to know the vertical images can by up to 4x5 ratio, i was not sure about that.
Instagram has a lot of unique quirks!
