Author Topic: BG with the AF-S 500mm f/4G today  (Read 1126 times)
« on: December 10, 2018, 01:54:19 »
It's heavy but I like to use it.
I'd like to see a comparison with the 500mm f/5.6 PF.
Nikkor Shooter
Re: BG with the AF-S 500mm f/4G today
« Reply #1 on: December 10, 2018, 02:17:00 »
Thank you for looking…
Are you kidding me?  :o
Thank YOU for the pleasure!
I really dig your renditions, Aguinaldo. 8)
That Heron fellow I won't have a chance to capture here!  :-[
« Reply #2 on: December 10, 2018, 03:48:56 »
Beautiful capture of the transmitted light of the leaves.  The composition looks nice, too!
« Reply #3 on: December 10, 2018, 09:36:17 »
The backlit leaves are super nice.
« Reply #4 on: December 10, 2018, 09:54:51 »
Sublime rendition, a pleasure to see. Very pleasing Light, PP and framing. Thank you
« Reply #5 on: December 10, 2018, 11:44:39 »
Thank you guys.
I forgot to say that I used a cpl-1l filter in the lens, but I think there was no visible effect in these shots.
Nikkor Shooter
« Reply #6 on: December 10, 2018, 13:52:52 »
… no visible effect in these shots.
I'll have to disagree with that statement…
Though a CP may have very negative effects through a wide
angle lens. It has only one drawback when used on a long lens:
may impair the full, proper performance of the AF system.
Otherwise, it is all beneficial in terms of colour.
« Reply #7 on: December 10, 2018, 15:11:22 »
I meant no significant effect. Unfortunatelly I didn't rotate the filter in these shots like I did in the shots below.
Thank you for the comment.
