Author Topic: What L bracket?  (Read 4378 times)
What L bracket?
« on: December 02, 2018, 09:34:18 »
What L bracket are you using with your D850?
There are quite a few brands offering a bracket all at different prices.
Eddie Draaisma
Re: What L bracket?
« Reply #1 on: December 02, 2018, 10:49:05 »
RRS BD850-UL; simple and solid single-piece design with a position locking pin. Good alternative for the RRS BD850-L two-piece bracket which has the disadvantage that the left straplet needs to be removed in order to have the l-part close to the body.
Re: What L bracket?
« Reply #2 on: December 02, 2018, 12:40:12 »
I have the Kirk BL-D850 -  works fine and I am quite happy with it.  this is size without the grip.
Re: What L bracket?
« Reply #3 on: December 02, 2018, 13:39:06 »
Thank you Eddie for recommending the light version bracket over the normal one.
Bob i will check out the Kirk they are only available from Germany but cheaper than the RRS option.
JJChan
  • JJ Chan
Re: What L bracket?
« Reply #4 on: December 02, 2018, 14:07:48 »
Fons - I use Sunwayphoto - not expensive but solid and rigid enough. Available on eBay and as cheaper OEM forms without the felt bag and Allen keys.
http://www.sunwayfoto.com/e_goodsDetail.aspx?gId=1445
Re: What L bracket?
« Reply #5 on: December 02, 2018, 14:53:09 »
I had the sunway with the d800; so many differences in prices the sunway goes for €75 and the RRS UL for €200.
And there is a Genesis L-Plate for €50.
Re: What L bracket?
« Reply #6 on: December 02, 2018, 15:18:13 »
that stuff breaks.. I know. you have to be careful the it is not cast aluminum instead of solid..
CS
Re: What L bracket?
« Reply #7 on: December 02, 2018, 15:23:59 »
Oooops, that could be an expensive experience.  :o
Carl
chris dees
  • Amsterdam
Re: What L bracket?
« Reply #8 on: December 02, 2018, 16:06:08 »
I use this one too. No problem sofar.
Chris Dees
Re: What L bracket?
« Reply #9 on: December 02, 2018, 16:35:42 »
I use the Really Right Stuff BD850-UL
I am still working on getting the right L-Bracket for the Nikon Z7.
Re: What L bracket?
« Reply #10 on: December 02, 2018, 17:35:22 »
Really?  I use Sunway ballhead, universal rail and camera plates and have had only positive impressions so far...
Thomas Stellwag
Re: What L bracket?
« Reply #11 on: December 02, 2018, 18:16:38 »
u can check the light one with home made strap in 11 days
Thomas Stellwag
Re: What L bracket?
« Reply #12 on: December 02, 2018, 18:40:40 »
I bought a lot of the Sunway stuff for mostly studio macro work.. definitely broke.
for all my work outside, I use Kirk.. always have. RRS is fine too.
JJChan
  • JJ Chan
Re: What L bracket?
« Reply #13 on: December 02, 2018, 18:56:05 »
I could see that happening. It really depends on use. Your photos are not just from high skills but also serious glass (Otus, big long lenses). I use and like the Arca Swiss ball head - but a friend of mine shoots big 600mm Canons and broke his. I use relatively dainty old lenses, nothing bigger than Zeiss 135mm and the Sunway has so far been adequate for my use.
Re: What L bracket?
« Reply #14 on: December 02, 2018, 19:02:32 »
just my recommendation.  Can't go wrong with Kirk and RRH and they all fit well too. Also the Kirk ballheads are great.
