Author Topic: Titanium lenswas given this lens to play with  (Read 1333 times)
Grahame Hamblin
« on: November 26, 2018, 20:24:29 »
Was given this lens to play with does any one know of it.
yes called titanium   lr series super wide macro .42 times af made in Japan looks like pentax mount
any info  would be helpful
Grahame
Re: Titanium lenswas given this lens to play with
« Reply #1 on: November 26, 2018, 20:26:01 »
Probably some kind of dioptre attachment. Can you provide us with a photo of it?
« Reply #2 on: November 26, 2018, 20:37:00 »
A quick google search confirmed my initial hunch. This is a frontal lens attachment with negative power thus the image field widens.
It goes without saying that concomitantly, resolution of the entire optical system declines at least to the same extent.
« Reply #3 on: November 26, 2018, 20:44:33 »
Grahame, I guess yours is this.
If so, this is a wideangle converter, as Birna noted.  It seems to come with the dedicated closeup attatchment.  Bower is the brand name also used for Samyang lenses.  "0.42x" should mean that this converter shortens the focal length of the master lens by 0.42 times.  37mm is the diameter of the filter thread of a master lens.  It could be designed for a small video camera?
charlie
« Reply #4 on: November 27, 2018, 06:43:00 »
I do believe so, I've got a Century Optics 0.65 wide angle attachment for my old camcorder somewhere. This is how they delineate attachment lenses for video cameras.
Grahame Hamblin
« Reply #5 on: November 27, 2018, 09:12:59 »
Thanks all for your help it was hopeless so gave it back. I think he had pulled it to bits and not reassembled it correctly
Grahame
charlie
« Reply #6 on: November 27, 2018, 17:49:10 »
These types of attachment lenses will not work on their own. They are designed for cameras with fixed lenses (consumer video cameras) that can not be interchanged. As mentioned when they are mounted on the front of an existing lens it will create a wider angle of view, using it by itself on an SLR type camera does not work and will result nothing but blur.
« Reply #7 on: November 27, 2018, 18:24:49 »
Typically you would screw such an attachment to a "normal" lens (approx. 50mm in case of the 24x36mm format, today known as FX or 'full frame') to get a wider view. Concomitantly you got a lot of barrel distortion and other optical 'goodies'.
« Reply #8 on: November 27, 2018, 23:09:37 »
I use the similar kind of fisheye converter on my Kenko pinhole for the super-wide pinhole photography, if the setup is still entitled as "pinhole".  :D
