Author Topic: Nikon D850 sec slot function?  (Read 3607 times)
« on: October 30, 2018, 11:46:13 »
Nikon D850 primary slot selection xqd, secondary slot function raw+ j.
However camera doesnt save a jpg on the sd card.
Am i overlooking a setting, doing something wrong here?
Re: Nikon D850 sec slot function?
« Reply #1 on: October 30, 2018, 11:51:07 »
Checking on the d500 for a similar setting, shows identical behaviour not saving a jpg on the sd card :o
« Reply #2 on: October 30, 2018, 12:32:29 »
When two memory cards are inserted in the camera, you can choose one as the primary card using the Primary slot selection item in the photo shooting menu (0 Primary Slot Selection).
Select XQD card slot to designate the card in the XQD card slot as the primary card, SD card slot to choose the SD card.
The roles played by the primary and secondary cards can be chosen using the Secondary slot function option in the photo shooting menu (0 Secondary Slot Function). Choose from:
Overflow (the secondary card is used only when the primary card is full),
Backup (each picture is recorded to both the primary and secondary card), and
RAW primary - JPEG secondary (as for Backup, except that the NEF/RAW copies of photos shot at settings of NEF/RAW + JPEG are recorded only to the primary card and the JPEG copies only to the secondary card).
« Reply #3 on: October 30, 2018, 12:49:51 »
Exactly so when i choose raw + jpg for the secondary slot i would think it will save a jpg on the secondary card but it doesnt neither for the d850 nor the d500.
Am i misinterpreting the information , dont know?
« Reply #4 on: October 30, 2018, 13:01:24 »
Excuses one will have to set image quality first to raw and jpg, since i never have done this i had overlooked this setting, my error.
« Reply #5 on: October 30, 2018, 13:45:05 »
That is funny!!! Congratulations!!!
Nikkor Shooter
« Reply #6 on: October 30, 2018, 14:05:41 »
Page 39 of the manual!
Thomas Stellwag
« Reply #7 on: October 30, 2018, 16:25:14 »
what  is that?   ;D
if i rememebr right, I had a similiar fun with getting bw pics out of the cam and forgot to add Jpeg to  the storage format
Thomas Stellwag
« Reply #8 on: October 30, 2018, 16:50:38 »
That must explain the antagony between the sexes, we dont read the manual ;D.
« Reply #9 on: October 31, 2018, 10:27:21 »
chances are low to meet a femail here, femail per Biology not per Gender theory that is. See forum statistics:
Male to Female Ratio: 23.3:1
