Author Topic: Wien, des Nachts  (Read 4261 times)
Re: Wien, des Nachts
« Reply #15 on: October 31, 2018, 18:58:42 »
I guess "Wien bei Nacht" or "nächtliches Wien" would be even better
« Reply #16 on: October 31, 2018, 19:19:03 »
Indeed, it is impossible to re-balance a scene that gets flooded by sodium HP bulbs, because the dominant part of the light is nearly monochromatic.
Better go for B&W, or de-saturate the yellows (selectively). With CNX-D, even that is not possible, but some overall de-saturation helps.
Selective de-saturation is also what I use with mixed color LED lights; in most cases, it is to avoid undifferentiated reds that make photos look like Van Dongen paintings.
Yep desaturate the appropriate color works really well for these strange hues of modern lights.
Very fine don PP in the above images with regard to this also.
Thank you, for the explanation.  Yes, the LED lights are tricky.  I just remembered that I had used the desaturation trick for the live performances where the stage lighting overexpose prime colors (especially reds and purples).  I often had to convert the images to B&W, when the strong colors are out of control.
But it has never occurred to me to use it for the incandescent or mixed lights.
« Reply #17 on: October 31, 2018, 22:28:47 »
Surely it should be  "Wien bei Noct"
« Reply #18 on: October 31, 2018, 22:33:06 »
Ich leike veraltete Redewendungen.
@John Geerts : isn't it terrible that I need a Noct to finally enjoy the darkness.
