Author Topic: Banding Issues with the Nikon Z6/Z7  (Read 7674 times)
« on: October 02, 2018, 09:43:47 »
This whole “banding” issue with the Z7 is something I hope one of you reading this can better explain to me. From what little I can gather, it is more easily seen in video rather than in stills.
Some critics suggest it is an anomaly mostly caused by artificial lighting and not a problem in natural daylight. Is it? And others say it is linked to only dark areas in a photo. And it is said that it is most obvious in Silent Mode, because like rolling-shutter, that mode takes more time to read the sensor and is thus the effect is introduced.
At any rate, some of the more technical photographers are worried about it and are in the process of checking it out. In any case, the banding effect seems to be slight and only even appears if we push the dark areas of a photo in post well beyond what is usual. Or, they say high shutter speeds and ISO are more prone to it. There are (at this point) all kinds of reports, not yet all aligned with one another.
As you can see, I am somewhat confused by this question, but also very interested to know how serious it is and how it will affect the work I do.
I wonder if anyone here has explored this with their Z7 (I have not received mine yet) and have opinions or a more confirmed explanation of what might be causing it or even if it is a problem.
Re: Banding Issues with the Nikon Z6/Z7
« Reply #1 on: October 02, 2018, 09:51:25 »
« Reply #2 on: October 02, 2018, 11:47:59 »
Ming Thein had this to say about the banding issue when I asked him:
"I saw it once when pushing contrast in an ISO 1600 long exposure (astrophotography experiment with the wrong lenses on hand) but that’s all. Normal exposure times don’t show anything that I’ve been able to detect so far, regardless of sensitivity."
« Reply #3 on: October 02, 2018, 12:11:41 »
The banding issue I mentioned would be annoying when one needs to prevent the highlight from being blown out and raise the shadow quite a bit, which I sometimes do.
But maybe you won't be in such a situation, so long as you use the camera for what you have been exploring.
schwett
    • photos
« Reply #4 on: October 02, 2018, 17:23:43 »
i believe you’re referring to two different things. under artificial light with a “refresh rate,” the fully electronic shutter of either the d850 or z7 produce very noticeable, fuzzy horizontal bands of light and dark. very noticeable and difficult to remove.
the z7 also exhibits, under really extreme circumstances, fine grained pattern noise which some suggest is related to the phase detect focus points. not sure if that’s true or not, but you’re much less likely to encounter this unless you’re really pushing the dynamic range.
it’s illustrated here:
http://www.photonstophotos.net/Charts/Sensor_Heatmaps.htm#mode=55,camera=Nikon%20Z%207,suffix=14,cameraC=NIKON%20D850,suffixC=14
« Reply #5 on: October 02, 2018, 17:39:45 »
Thanks, that is very helpful.
Ethan
« Reply #6 on: October 03, 2018, 11:03:14 »
Reading photography gears reviews and images critiques is turning to be a very entertaining succession of moments.
So there is a guy who "allegedly" is shooting side by side the same chart or scene with a D850 and a Z7.
Lo and behold, he discovers that banding occurs heavier in the Z7 than the D850 when the EV is pushed between +4EV and +6EV !!!!
Yeah, right, one guy is on low ISO but only shows the ISO and  speed.
Another guy goes up to ISO40000+ ???????
And the third guy had banding shooting the stars!!!!!!!!!!!!!!!! at long exposure!!!!!!!!!!!!!
Really? I mean really?
I once put my Iphone in my back pocket and the camera was turned on by mistake. I only found out when my bum became hot. Me think I should do a review on the Iphone with he negative point that if you keep your Iphone camera on, it will warm up your bum. Or it could be perceived as an additional benefit for the Iphone for the so inclined people.............. Dohhh
Well, it is very entertaining to a certain degree reading comedian reviewers!
« Reply #8 on: October 04, 2018, 08:10:17 »
The banding seems to be very similar to what I saw on the Leica SL when lifting exposure or shadows in PP which I do on some images,,,
http://nikongear.net/revival/index.php/topic,1833.msg23602/topicseen.html#msg23602
« Reply #9 on: October 04, 2018, 09:16:01 »
Erik, so far as I understand, the AF of Leica SL is CD only and the snsor doesn't have PDAF photosites.  So, the cause of the banding should be different...
« Reply #10 on: October 04, 2018, 09:29:19 »
Yes I agree, this may be different causes, but the point it that it makes it impossible to edit the image more than a few stops in PP, since it's nearly impossible to remove this banding.
Please note the the SL sample posted by me was at ISO 125 and not an uncommon scene where one would lift shadows,,,
« Reply #11 on: October 04, 2018, 09:37:38 »
Yes, I remember your sample image suffering from the banding.  IIRC, the last Nikon DSLR that suffereed from the banding noise (for whatever reason) was D7100, but only at very high ISO settings.
« Reply #12 on: October 04, 2018, 09:47:03 »
I remember banding was easily induced wih the D700.
« Reply #13 on: October 04, 2018, 09:53:19 »
I don't recall there was a banding issue with D700, do you have a link for that?
  • Fairbanks, Alaska
« Reply #14 on: October 04, 2018, 12:06:02 »
IIRC, the last Nikon DSLR that suffered from the banding noise (for whatever reason) was D7100, but only at very high ISO settings.
My experience is that D7100 shows most pronounced banding at base ISO (100) with exposure compensation + shadow lifting. (I usually try too keep it to max +1EV exposure compensation + 50% shadow lifting to avoid problems). At higher ISO it will be buried in the noise, so it will then not show in practical situations. I have yet to see it in severely stretched astro images recorded at ISO 1600. Bill Claff has some tests on his site, http://www.photonstophotos.net/Charts/Sensor_Heatmaps.htm
The Z7 raw files I have examined (from DPR) shows similar properties with respect to being most pronounced near base ISO, but much less severe, and more regular/finer banding pattern than D7100. It also seems inconsequential as to when it then shows up in the Z7 images.
