Author Topic: Snorkeling the Silfra fissure in Thingvellir Park, Iceland  (Read 4999 times)
Re: Snorkeling the Silfra fissure in Thingvellir Park, Iceland
« Reply #15 on: November 23, 2018, 11:24:22 »
What an adventure !   Greatly documented.
« Reply #16 on: November 23, 2018, 12:13:16 »
Thanks for the kind comment Jakov. I have heard there are some bigger fish in Thingvellir Lake further out, but the Silfra Fissue is itself likely too low on nutritients to be interesting for the fish to enter. Keep in mind that cold water is in many respects good for the fish as it dissolves more oxygen.
Yes, a Z-mount series Nikonos that could go to scuba diving depths would be something, although a quite an expensive piece of equipment to drown...
Then Nikon should make an AW2, whichever way, I want an update :)
  • Fairbanks, Alaska
« Reply #17 on: November 23, 2018, 23:01:46 »
Thanks John and Jakov for further comments.
On the technical side is to notice the synergy between the AW 10mm f/2.8 and the Olympus fisheye converter. I previously showed this effect at a close range in the AW1 review. Pincushion distortion of the 10mm under water is cancelled by the "fisheye" effect of the the converter (seen for land shots). This was a rare case to show that these two effects also cancels each other close to infinity resulting in water surface that are not much curved but straight.  (No distortion correction were applied in any of these captures).
« Reply #18 on: November 24, 2018, 01:17:37 »
Man! ... What an adventure. My hat's off to you for venturing into such cold water.  That clear water must be such a joy to dive through.  Thank you for sharing.
  • Fairbanks, Alaska
« Reply #19 on: November 24, 2018, 08:56:42 »
Thanks for the comment Gary. It did not feel cold - the provided drysuits were very thick (with thick insulation beneath + the merino wool base layer provided by myself), and one basically just had to know how to swim. Due to all the buoyancy keeping us at the surface, I found slow frog kicks more efficient that the regular kicks with fins, allowing more steady swimming with respect to the video capture. I still need to cut/edit some of those clips together...
