Author Topic: I should really not be allowed out unsupervised by a responsible adult  (Read 4593 times)
Re: I should really not be allowed out unsupervised by a responsible adult
« Reply #15 on: September 11, 2018, 16:33:37 »
As soon as you remove the barrel distortion they are gone, a little homework on the camera will tell you a lot about the camera. LEICA User form for instance;)
The barrel distortion seems to be pretty pronounced.  The lens could be designed with the premise of the digital correction.
Eddie Draaisma
« Reply #16 on: September 11, 2018, 16:36:59 »
Yes, it is very pronounced. Correct it in post and the vignetting is gone.
CS
« Reply #18 on: September 11, 2018, 16:47:15 »
That's automatic for me shooting Nikon, no matter the lens, and LR makes it easy as long as the lens is in it's database.
Carl
« Reply #19 on: September 11, 2018, 16:48:44 »
Viv
« Reply #20 on: September 11, 2018, 16:52:07 »
The corners are fine when shooting jpg.
The Barrel Distortion Correction tool in Photo Ninja does not cure the problem when processing the RAW file.
It seems the camera is not supported by Photo Ninja.
« Reply #21 on: September 11, 2018, 16:56:14 »
Could you post the JPEG (straight out of the camera, just resized)?
The angle of view should be significantly different from that of the RAW image posted initially.
Viv
« Reply #22 on: September 11, 2018, 17:02:07 »
Nope. That image exists only in RAW.
Eddie Draaisma
« Reply #23 on: September 11, 2018, 17:03:06 »
for those who want to play with this significant (barrel) distortion: some Leica Q raw files can be found at: https://www.photographyblog.com/previews/leica_q_typ_116_photos/
Eddie Draaisma
« Reply #24 on: September 11, 2018, 17:18:55 »
Correcting the distortion of the Leica Q files sometimes leads to visibly less sharp corners. Not exactly my cup of tea. Didn't the shop have a nice M10 with e.g. a 35mm Summilux in stock??  ;)
« Reply #25 on: September 11, 2018, 17:24:47 »
The recent incarnation of Photo Ninja deals easily with the Leica Q DNG format as such. However, one has to do a manual distortion correction if it is desired to get rid of the dark corners.
Viv
« Reply #26 on: September 11, 2018, 17:31:20 »
Thanks. I do not have the latest version.
Will investigate.
Viv
« Reply #27 on: September 11, 2018, 19:40:08 »
Yes. I just tried it and it works.
Thank you for your help.
Seapy
« Reply #28 on: September 11, 2018, 19:47:44 »
Better solution than a hacksaw!  ::)
Robert C. P.
South Cumbria, UK
« Reply #29 on: September 11, 2018, 22:31:42 »
Congrats!
Specially on a brand new Leica  ;D
