Author Topic: Did You See That?  (Read 4207 times)
Nikkor Shooter
Did You See That?
« on: September 09, 2018, 19:43:27 »
Re: Did You See That?
« Reply #1 on: September 10, 2018, 20:39:36 »
I'm slightly distracted by the white point in front of them and the bubbles above but the most annoying thing is I can`t help thinking the upper part on the left side of the left reflection has been cut. Looking at the reflection of the right egret, it is similar so maybe it is the proximity and alignment of your copyright notice that is creating a cognitive artifact by suggesting a cut, I don`t know. In the end, I'm unfortunately always looking at the "cut". If the copyright was on the right side, maybe it would be different.
That said, I would be very pleased if I had taken it myself.
Nikkor Shooter
« Reply #2 on: September 30, 2018, 06:59:03 »
I'm slightly distracted by the white point in front of them and the bubbles above but…
The bubbles are floating feathers — as is the one in
front — and I see them as part of the environment.
… the most annoying thing is I can`t help thinking the upper part on the left side of the left reflection has been cut. Looking at the reflection of the right egret, it is similar so maybe it is the proximity and alignment of your copyright notice that is creating a cognitive artifact by suggesting a cut, I don`t know.
Nothing was change for the sake of the watermark that
I prefer to place behind the subject.
Thank you Bruno! :P
