Author Topic: one camera, one lens, one week, one place  (Read 4327 times)
Re: one camera, one lens, one week, one place
« Reply #15 on: August 21, 2018, 14:15:52 »
By the way, I love #4 from the library series.  The light throuigh the oval window is diffused beautifully.  Also, the image reminds me a bit of "2001" by Stanly Kubrick.
the workplace with the globe made me want to sit there immediately and work. The 89 year old librarian found it a pity that noone uses that nice place. The library is closed to the public, only monks and guests are entitled to use it
« Reply #16 on: August 21, 2018, 14:19:36 »
Yes I think that more Clarity and/or B&W would yield more impact - Question is, do you want more impact  ;)
currently I am scanning my output still and decide which pictures to use. My first impulse was to document and make the colors look very much the way they appeared to me in real life. Maybe with more distance I want to revisit the set.
Take this as an example: the light is before dawn and I intentionally chose the underexposed shot from the BKT set of three for my edit because I wanted the greens to appear as saturated and deep as I experienced them in that moment. Here the edit adds an emotional dimension.
The vignette of the Neo-Noct at 1.4 adds some drawing magic.
« Reply #17 on: August 21, 2018, 14:27:11 »
Great series of very nice shots ! The library is fantastic !!!
The "one camera, one lens, one place" is a great exercise, almost mystical... :)
If the lens is of some flexibility, like the 58mm or 85mm. I guess one week with fisheye only would not yield such a variety of shots. Here the hand of mentioned librarian and the "Kreuzgang" normally closed to the public.
PS thank you for your help with the diagnosis. The infection cancelled itself out before anyone could identify it.
« Reply #18 on: August 21, 2018, 14:39:55 »
Beautiful series, there are some magnificent sculptures,  I'm also drawn to the globe in the library image, the hand with the seal ...
It most have been a  very restoring experience
« Reply #19 on: August 21, 2018, 14:49:35 »
Yes, indeed, great series.  Love especially the light in #2.
« Reply #20 on: August 21, 2018, 15:34:37 »
thank you, Armando with more sculptures that just came back from restoration:
« Reply #21 on: August 21, 2018, 15:36:23 »
thank you, John.
The hidden room where the monks swear their oath:
« Reply #22 on: August 21, 2018, 15:58:57 »
Your white balance seems to drift,
« Reply #23 on: August 21, 2018, 17:52:34 »
in the room with stained glass windows, dark woodden ceiling and walls I kept the orange tint. In which picture do you think a different WB would make the result better?
« Reply #24 on: August 21, 2018, 23:25:55 »
More or less all of the indoor images have some degree of variation, kind of makes the series look a bit off or
« Reply #25 on: August 21, 2018, 23:47:31 »
I will check that on a calibrated system. The Notebook is not a good reference point
« Reply #26 on: August 22, 2018, 08:30:05 »
An enterprising set of shots of an interesting place, with the one lens selected being 'not wide' making the challenge very high. The off-center placement of plane of focus in many of the shots requires viewing on a large monitor...didn't work on the laptop.  Mixed light sources, in this case low tungsten and cool daylight/skylight, and flat light are sometimes an annoyance.  Not sure what can be done about the mixed colors, outside of hue manipulation, and that doesn't always work.  Thanks for posting these.
« Reply #27 on: August 22, 2018, 15:35:39 »
love to hear from you, Keith
