Author Topic: Monochrome sensor portraits  (Read 1871 times)
« on: August 12, 2018, 20:36:16 »
D800M,Carl Zeiss Otus 1.4/55
1/60s f/5.6 at 55.0mm iso250
1/40s f/5.6 at 55.0mm iso320
1/100s f/5.6 at 55.0mm iso250
and a stuffed animal
1/160s f/2.2 at 55.0mm iso250
Re: Monochrome sensor portraits
« Reply #1 on: August 12, 2018, 21:17:53 »
The detail in the hair looks impressive, is it?
« Reply #2 on: August 12, 2018, 21:53:10 »
i am not sure of the question.. but this is an alpaca hat.
« Reply #3 on: August 12, 2018, 21:56:29 »
Sorry I´m not clear. I was seeking confirmation about the amount of detail in the files. It looks like it renders small details with great definition.
« Reply #4 on: August 12, 2018, 22:29:50 »
theoretically yes.  my task has been to find subject matter that brings that out.. i will say with the manican that the amount of shadow recover while preserving detail in the hat was impressive to me.
« Reply #5 on: August 13, 2018, 00:11:25 »
I'm seeing an odd patterning in the first and last images. There is a screen pattern over the face and light areas of the background. Are these present in the original photos?
« Reply #6 on: August 13, 2018, 00:36:45 »
These look amazing, but it would be impossible to fully appreciate the potential of D800M with these images in the posted size and on my computer screen.  Awesome camera!
« Reply #7 on: August 13, 2018, 12:20:53 »
yes.. this is an artifact of turning demosaic off using a raw processor such as Monochrome2DNG or DarkTable... which does not dither the resulting pixels.  I have reprocessed the 1st image using AccuRaw which does a 1-pixel dither (i believe) that is designed for images where the CFA was removed. This artifact has become an issue on occasion. If i just drop these images into photoshop they will demosaic as if there was an RGB Bayer area present.
Macro_Cosmos
    • Flickr
« Reply #8 on: August 14, 2018, 05:15:55 »
D800 is cheap nowadays, I'm looking to buy one and get a friend specialising in camera modding to convert it into BW by scraping the Bayer Matrix off.
I have some questions though:
1. Which raw converter is needed? The camera would definitely apply some stuff to the raw file that amplifies/suppresses each colour pixel that it thinks it's there. This will as I would imagine, generate a RAW file with some sort of mosaic pattern of different gradients of grey.
2. I've read on Nikonhacker, that they have a firmware with "true dark current" and "original raw generation", would this be needed? If I apply it, would it be possible to drop the raw files into Capture One Pro or LR?
3. Would it then be important to use UV or UV-IR filters on the lenses?
Any tips would be appreciated.
Blog: Diatoms Australia
« Reply #9 on: August 14, 2018, 09:14:00 »
i would contact MAXMAX.com  - doing this conversion correctly is no simple matter.
« Reply #10 on: August 14, 2018, 12:18:09 »
Raw Converters with capability to bypass demosaic operation - DarkTable, RawTherapee, Monochrome2DNG, AccuRaw
Macro_Cosmos
    • Flickr
« Reply #11 on: August 22, 2018, 16:00:45 »
Yeah I agree. I'm not confident to do it myself. The friend I have is happy to take it to task though, he's modded several cameras already. In exchange, I'm bringing him sand samples from various local beaches :P
I'll look into the raw converters you've mentioned.
« Reply #12 on: August 23, 2018, 00:43:09 »
does he have the ability to plasma etch off the CFA and microlenses?.... the yield for this operation sometimes requires more than one sensor..
