Author Topic: XQD Card Reader  (Read 5151 times)
ArthurDent
XQD Card Reader
« on: July 17, 2018, 20:45:38 »
Any suggestions on a reliable reader? I've been having problems transferring files when I hook the camera up to my computer directly.
Re: XQD Card Reader
« Reply #1 on: July 17, 2018, 22:01:07 »
I'm using either a Sony XQD Expresscard Adapter (QDA-EX1) or a Sony XQD card reader (model MRW-E80/USB3). No problems with either option.
Re: XQD Card Reader
« Reply #2 on: July 17, 2018, 22:05:07 »
I had a lot of trouble with card readers until I bought Lexar Professional Workflow, one for XQD, one for SD
Eddie Draaisma
Re: XQD Card Reader
« Reply #3 on: July 17, 2018, 22:21:47 »
Another option is the Sony MRW-E90; it has an SD card slot in addition to the XQD card slot and works well. Also USB-3.
Re: XQD Card Reader
« Reply #4 on: July 17, 2018, 22:50:56 »
I’m using a “Sony XQD USB Adapter for G Series” model QDA-SB1A. No problems; except that, from time to time, you have to reintroduce the card twice before it marks.
Was delivered free with my first D5.
Ashlandish
Re: XQD Card Reader
« Reply #5 on: July 18, 2018, 02:50:25 »
I've been using a Sony XQD/SD Card Reader (MRW-E90/BC2). Works fine, and the SD reader is occasionally useful.
Tim Becraft
Re: XQD Card Reader
« Reply #6 on: July 18, 2018, 03:10:34 »
I have a lexar. not so bad but a bit expensive  :o :o :o
Nikkor Shooter
Re: XQD Card Reader
« Reply #7 on: September 07, 2018, 23:31:20 »
Since I got the D850 last December 2017, I had to get
a Thunderbolt 3 compatible XQD card reader for the new
iMac i7 5K. I opted for the Sony MRW-E90. This combina-
tion is extremely fast and yet I found only one thing that
is not to worry too much: the unit is getting very warm
even if it is just plugged in… without a card!!!
Luke Miller
    • Luke Miller - Photographer
Re: XQD Card Reader
« Reply #8 on: September 08, 2018, 16:34:47 »
That is what I use with my Sony XQD cards.  I found the Lexar Workflow XQD modules are generation specific.  So I have one module for Gen 1 and another  for Gen 2.
Seapy
Re: XQD Card Reader
« Reply #9 on: September 08, 2018, 19:03:14 »
I found only one thing that is not to worry too much: the unit is getting very warm even if it is just plugged in… without a card!!!
Perhaps the circuitry is searching very hard for a card?
Robert C. P.
South Cumbria, UK
Re: XQD Card Reader
« Reply #10 on: September 08, 2018, 19:38:15 »
Another vote for the Sony MRW-E90 as the Micro-B to USB cable can be very easily replaced by an Micro-B to USB-C cable which makes it a future proof investment.
In my case I've ordered the Belkin Micro-B to USB-C cable at the Apple store:
https://www.apple.com/shop/product/HHST2ZM/B/belkin-usb-c-to-micro-b-cable-usb-31?fnode=8b
Nikkor Shooter
Re: XQD Card Reader
« Reply #11 on: September 08, 2018, 21:29:09 »
With or without card in… just connected Robert!
MILLIREHM
  • Vienna, Austria
Re: XQD Card Reader
« Reply #12 on: September 08, 2018, 23:54:29 »
Bought a Sony MRW-E80 XQD reader first. Mostly it works without problems but sometimes it needs repeated reconnections following trial and error to finally work. It is not foreseeable when this occurs and when it does not.
Added a MRW-E90 dual slot card reader (XQD and SD) because I found it convenient to have one reader for the two main card types (was using a Lexar USB 3.0 reader for CF and SD before). There is no problem with SD. Strangely it is working with all my Lexar XQD card except one (same type). There is never any Problem to read the new Sony 128GB XQD i bought for the D850.
Wolfgang Rehm
Nikkor Shooter
Re: XQD Card Reader
« Reply #13 on: September 09, 2018, 00:14:31 »
Confirmed… but do you notice the warmup of the unit?
Grüße aus der Streiermark
Seapy
Re: XQD Card Reader
« Reply #14 on: September 09, 2018, 00:16:26 »
Ah! Thats easy... The reader is scouring the card for data, either way these computer thingamajigs find a way to stay busy and burn off your electric to make heat.  ::)  ;D
Robert C. P.
South Cumbria, UK
