Author Topic: Nikon D5 firmware update  (Read 3555 times)
« on: May 25, 2018, 22:18:14 »
Nikon has released firmware version 1.30 for its D5 professional DSLR, and the new camera firmware offers an additional feature that's potentially very useful: recall shooting functions.
The latter has always been on my wish list, enabling me to switch very fast from one shutter speed configuration i.e. slow speed (1/40 s) to a very high one (1/4000 s).
More, here https://www.dpreview.com/news/9509232063/nikon-d5-firmware-update-adds-useful-recall-shooting-functions-feature
And here: http://download.nikonimglib.com/archive3/fG6ww00zTqqv03yTvDs53coSDj35/D5FirmUpv130_EU(WA_DL)01.pdf
Download here: http://downloadcenter.nikonimglib.com/en/download/fw/276.html
chambeshi
Re: Nikon D5 firmware update
« Reply #1 on: May 26, 2018, 16:26:30 »
This firmware update brings a new function to the D5 - Recall Shooting
Steve Perry just posted about its applications. Sure hope we see the D500 and D850 updated in the future :-)
https://backcountrygallery.com/nikons-new-recall-shooting-feature/
« Reply #2 on: May 27, 2018, 18:11:45 »
An example: when shooting car races I'm using quite long exposures up to 1/40s to well render a speed blur:
ƒ/29.0  370.0 mm 1/60s  ISO 100
but when something happens, a collision, for example, I would have liked to switch to 1/2000s instead of a 1/50s
Up to now, before the recall shooting function, this was not possible.
« Reply #3 on: May 28, 2018, 10:02:58 »
you are better off using a neutral density filter than f/29 due to diffraction softening of the image (even though that looks plenty sharp)
« Reply #4 on: May 28, 2018, 11:10:41 »
Thank you Bob: I'm generally lower than that. But the image degradation due to diffraction is negligible compared to the image degradation induced by catching high velocity subjects at shutter speed averaging 1/50s. And I have to switch often to higher shutter speeds, which makes switching ND filters impractical.
Have a look at this one taken at f/20 and 1/40 s:
https://mfloyd.prodibi.com/a/2x9y7yxg9w89r8/i/w02jeg7mqwywgv
HR Prodibi image - click on the lower right corner to change size.
« Reply #5 on: May 28, 2018, 11:31:48 »
yes.. understand
« Reply #6 on: May 28, 2018, 11:32:36 »
yep.. plenty sharp
« Reply #7 on: May 28, 2018, 11:42:54 »
yep.. plenty sharp
 :) ;) but you are not the first one to raise this question. The only thing of which I would have concern is the increased DoF; which is (should be) largely wiped out because of the speed blur... But I will have a try.
« Reply #8 on: May 28, 2018, 12:13:25 »
A 'pop-up' filter drawer would help speed things up switching the ND filter in and out - that would not be too difficult to make for the tele lenses with filter drawer.
Would also make it for the Polfilter as well,,, but a dedicated version might be needed.
Sort of the same/similar solution as the new 180-400mm that pop in the TC in and out,,, or like the really old dias projektors did with the slides.
All the filter-wheel designs don't really work here i think,,,
« Reply #9 on: May 28, 2018, 12:22:49 »
I understand what you want, but this image looks quite dramatic!
« Reply #10 on: May 28, 2018, 15:25:24 »
I encountered a more trivial problem: Nikon - in Switzerland, at least - doesn’t sell separate 52 mm filter holders for e.g. a 300 mm f/2.8 lens. I needed this, in order not to have to unscrew, each time the filter, and so, make a faster switch. Finally Nikon provided me with an adress of an independent supplier who sold me the original Nikon part (?!).
Hello Akira, not sure if the frozen, high shutter speed, picture would have given the same dramatic effect  :)
« Reply #11 on: May 28, 2018, 20:04:10 »
I think the theory is fine Bob, but have you ever attend a race meeting?
The practicalities of switching ND filters in & out as cars are whizzing past make MFloyd's solution the preferred one :)
Ann
« Reply #12 on: June 19, 2018, 21:43:39 »
The latest D5 Firmware update can record a number of variables in the saved settings for "Recall shooting functions" including whether or not ISO is in the Auto or in pre-set mode.
The way in which I have mine set is to save my settings in Manual mode, with fully-open aperture, a moderate shutter speed, and with Auto ISO.
That way when I suddenly need to grab a subject in dim conditions and hold down my chosen modifying button, the camera has an excellent chance to get me a usable exposure.
« Reply #13 on: June 20, 2018, 07:26:37 »
sounds terrific, Ann. I guess the new 850 Firmware can do the same?
Ann
« Reply #14 on: June 20, 2018, 08:03:11 »
I don't think so, Frank. It seems that the D850 FW update is only about time zones but perhaps the next version will have Recall Shootng.
