Author Topic: How to remove the coating from a lens?  (Read 4554 times)
Macro_Cosmos
    • Flickr
Re: How to remove the coating from a lens?
« Reply #15 on: May 15, 2018, 06:15:00 »
Image quality will be drastically reduced if you do that. I suggest buying a lens that works well in the UV range. Bjorn's site has an excellent list  ;D
If you don't mind, it's still a fun project. Keep in mind that some glass elements are actually doped with various substances, rather than coated. These doped glass could affect UV transmission as well.
Blog: Diatoms Australia
Andor Zyla 5.5 sCMOS | Hamamatsu ORCA-Flash V2 | Nikon Z6 | Olympus Microscope
Steven Paulsen
  • Cumpulsive Tinkerer
« Reply #16 on: May 16, 2018, 18:19:50 »
I worked as an optician for many years & I discovered this trick on my own. (Use at your own risk, & this applies to plastic & glass eyeglass lenses.)
The coating always scratched & even flaked off on earlier applied coatings. I removed the lenses from the frame & soaked them for a few hours in common drain cleaner, a mild version of sulfuric acid. It did not effect the hardened scratch coating on common CR39, (plastic,) and no issues on glass, either.
This may work, if you can remove a lens element of your photo lens. I would be cautious of "wiping a lens' If you have a pair of glasses with damaged anti reflective coating, you can bring them back service using the above method.
« Reply #17 on: May 16, 2018, 22:55:17 »
While your experience with using drain cleaner to remove AR coatings is useful knowledge, in the interests of safety and accuracy, I submit to the forum that in the USA, the common drain cleaners are not acidic but strong alkalis, in most cases sodium hydroxide.
MSDS's from two common brands:
ArthurDent
« Reply #18 on: May 16, 2018, 23:42:24 »
This is correct. I don’t know how it is done elsewhere, but in America, drain cleaners work by reacting the built up grease with a base (NaOH) in a saponification reaction to form a soap which is easily dissolved with water and flushed down the drain.
Steven Paulsen
Dear Drano Police
« Reply #19 on: May 17, 2018, 04:45:16 »
Sorry. I assumed it was all the same. I buy the expensive stuff that is only carried in a few hardware stores. A one quart plastic bottle, with a heavy plastic bag, over wrap. It costs Around $15.00, and lists the active ingredient as sulfuric acid.
I have a mix of copper, iron & pvc in my home. A couple times upon dumping in a small healthy dose, I've gotten a rise of smoke. I am an old, photographer, musician, (long hair, hippy type.) The stuff takes care of hair clogs quickly. (Dump, vacate, wait a minute or two & rinse with cold water. I'll also add, the low cost domestic stuff does the job, on lenses, but not near as fast. (Usually an overnight soak & is fairly useless on bath tub, shower clogs.)
My apologies, and/or, GFY
 8)
Re: Dear Drano Police
« Reply #20 on: May 22, 2018, 08:47:56 »
I still think this approach is not a valid one, gettting a (cheap) UV capable lens does the trick much better....
