Confinement and inaction gave me the opportunity to think over the purchase of a “real” tripod and ballhead. The stuff I have for years is just junk. As a sport / action photographer, the use of a tripod is about nil, if not forbidden. The only accessory of this kind I’m using is a monopod (carbon Sirui) equipped with a quick release clamp from Really Right Stuff (RRS). And even the use of monopods became quite marginal with last year’s purchase of the Nikkor 500mm f/5.6E PF.
So why a tripod ? I (would) like to make some landscape pictures, time exposures and some astro photography for which a stable tripod is a must. But I disregarded the purchase as being too expensive for the rather marginal (non professional) use of such costly device, at least when you are aiming for quality.
Finally I made the jump by investing (?) $2’000 bucks in a RRS tripod and ballhead. All due to arrive today by my gentle postman.
The ballhead, is a beefy BH-55 ballhead:
RSR BH-55RRS TVC 34L Mk 2 & BH-55and a carbon tripod from RRS. I, finally ended up to go for a TVC 34L Mk2 tripod, TVC standing for Tripod, Versa, and Carbon. The only term needing some explanation is Versa, which stands that the top plate / assembly of the tripod can be changed. The first digit stands for weight category going from 1 to 4, 3 is OK for supporting up to 50 lbs. The second digit, stands for the number of leg sections: 4 sections with regard to transportability (3 being the ideal for sturdiness, but 4 seems still OK); L for the tall version going as high as 180 cm.
RRS TVC 34L Mk 2 & BH-55More explanations here:
https://www.reallyrightstuff.com/tripod-guideMore feedback later
