Need some basic understanding to cope with the rising sun into full springtime, eventually Summer
During the winter, my D750 has been on 400. all the time.
I think it is best not to limit one's shooting habits or shooting situations based on the time of the year. Rather than calendar, use your camera's exposure meter to determine which settings (including ISO) are most beneficial to the image you want to capture.
A very simplistic approach to exposure:
CASE A: not very fast moving subjects
1. Begin: set the ISO setting to the base ISO of your camera (ISO 100)
2. set your camera to A mode (aperture priority)
3. determine the depth of field your image requires and set the aperture accordingly
4. check the shutter speed your camera chooses, if it is too low (camera shake) use tripod, use VR and/or raise ISO until shutter speed is "safe"
5. shoot the picture
See pages 91-92 and 134-142 in the english user manual.
CASE B: fast moving subjects
2. set your camera to S mode (shutter priority)
3. determine the shutter speed your subjects require (action stopping-> high SS, panning and/or motion blur -> lower SS). Set the shutter speed accordingly.
4. check the aperture value your camera chooses, if it already maxed out (camera displays "Lo"), raise ISO until an actual F-number is displayed; or lower shutter speed if possible.
See pages 90 and 134-142 in the english user manual.
ISO 100 in the midnight in the winter (I'm in Finland) is perfectly usable. ISO 12800 in daylight in summer is perfectly usable. You decide what you want.
After you master the cases A and B above, you can use exposure compensation (manual pp. 143-144) when required and of course you can use deliberate underexposure and overexposure at will when your pictorial needs so dictate. And remember to have fun!
Too long, didn't read version: Use the ISO setting last, after everything else. This approach usually minimizes digital noise. Start from the lowest and raise only when necessary.
Link to download the english manual:
http://download.nikonimglib.com/archive3/nbv9u00rNwcC03nAlhH22OsaSF95/D750FM_DL(En)03.pdf
