Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
*** Welcome to the new NG Server ***
Current status:
106/150
supporters
Home
Help
Login
Register
NikonGear'23
Gear Talk
What the Nerds Do
P6 to F distance?
« previous
next »
Print
Pages: [
Go Down
Author
Topic: P6 to F distance? (Read 1578 times)
CardBoardBoxProcessor
NG Member
You ARE NikonGear
P6 to F distance?
on:
April 09, 2018, 15:13:16 »
High, hoping to make a quick adapter on my 3d printer for proof of concept for a future more advanced tilt shift adapter. But I need to know the distance from The very rear of a Pentacon 6 bayonet in (male) the the back end of the F mount ring. whats the distance between the two.
Logged
Homo jezoensis
NG Supporter
Tokyo, Japan
Re: P6 to F distance?
Reply #1 on:
April 09, 2018, 16:24:35 »
Hi, here you can look into the flange back of all sorts of lens mounts:
https://en.wikipedia.org/wiki/Lens_mount
According to the wiki, the flange back of Pentacon Six mount is 74.1mm. Nikon F-mount has 46.5mm flange back, so the difference is 27.6mm.
This calculation is, of course, based on the assumption that the wiki datum is correct. Everyone here should know the flange back of F-mount, though.
Logged
NG Member
You ARE NikonGear
Reply #2 on:
April 09, 2018, 20:16:06 »
Ah. I was not aware the definition of the word I was searching for. "Flange back" so that is generally considered uniform?
Logged
NG Supporter
You ARE NikonGear
Reply #3 on:
April 09, 2018, 20:22:25 »
I have seen Flange to Film, Flange to Focus(technically, probably the most correct term), Register Distance, Register, Flange Distance. There are probably more terms that others can contribute.
Logged
Homo jezoensis
NG Supporter
Tokyo, Japan
Reply #4 on:
April 10, 2018, 10:28:03 »
So far as my understanding goes, "flange back" may be more of a common term rather than the specialists' term.
So far as "flange something" is not mixed up with "back focus" (which is the distance between the sensor/film and the tip of the rear-most optical element), the confusion could be minimized?
Logged
Print
Pages: [
Go Up
« previous
next »
NikonGear'23
Gear Talk
What the Nerds Do
P6 to F distance?
